Chris NottAH Fabrications
Results 1 to 17 of 17
Like Tree3Likes
  • 1 Post By Marshy
  • 2 Post By Brodster
Thread: Post mapping - high(ish) pitched noise on boost?
    Muzza80's Avatar
    Oct 2013
    Glasgow
    333
    Hi all,
    Just got my 2010 S3 Sportback stage 1 Shark mapped by Brodster on Saturday.
    Firstly, what a map, very smooth in delivery and the mid-range torque increase along with how long the boost holds now is quite something, really impressed, thanks again Mark.
    One little issue though.
    When really getting the power down, especially in 2nd, 3rd and 4th as soon as the car comes on boost I'm getting quite a high pitched chirpy squeal from the engine bay, pretty noticeable. It's not turbo whistle and it's only when on boost so not the compressor stall noise that I see a lot of people query.
    Sounds a little like a split recirc valve diaphragm I had on my old stage 3 Astra VXR but what I've read my March 2010 car should have come fitted with the revision D recirc valve which does not have a diaphragm? I've not checked yet will do later in the week.
    Just wondered if anyone had noticed the same thing or any other ideas as to what it might be?
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    I was talkibg to Mark mate and he was saying you got the map done and was gonna ask you how you found it? So that pretty much clears that up.... DV is easy enough to remove and check as its right at the front of the bay... Dunno if its still easily accessable with the engine cover on, but mines is off the now so couldnt tell you ..
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    Jun 2013
    280
    If it is ur DV u get one from gfb which I basically an insert that fits if the one I got if before my map think its about £80
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,617
    Quote Originally Posted by Gfermer View Post
    Wish it was 80 Audi S3 2.0 TFSi GFB DV+ Diverter Valve T9351 | eBay
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    380
    Could be one of the boost pipes leaking boost at high pressure.
    The notorious o-rings on the intercooler pipes are a favourite.
    The DV on your 2010 will be rev D so I'd doubt that would be causing it.
    Muzza80 likes this.
    IBIS WHITE S3
    Revo stage 1, Loba Hpfp
    Muzza80's Avatar
    Oct 2013
    Glasgow
    333
    I'll get the recirc out and have a look later.
    Failing that then I guess I'm looking at a boost leak then somewhere, joy!
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,209
    Follow Brodster On Twitter Add Brodster on Facebook
    Im sure it's DV flutter which the +valve will cure. Mine makes this noise now and again and it goes like a train. I might stick this new valve on and see if there is a difference.
    Anyone wanting a group buy for this as I will phone Shaun at AMD Essex and see if he has enough stock.
    S3_Jacko and Muzza80 like this.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/VCDS/Wagner
    Muzza80's Avatar
    Oct 2013
    Glasgow
    333
    Quote Originally Posted by Brodster View Post
    Cool, I'm just away to check mine just now and run a datalog to check for requested and actual boost to see if there's a leak in the system anywhere.
    I really like the look of the AMD ones, if you could get a discount on them then all the better, they look like the best engineered solution to me having looked at various types today.
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,209
    Yeah I think I will get one for my S3 too so leave it with me Murray and I shall get back to you. Did you hear the news that Im now a BCS exhaust dealer now.......just for you buddy........lol
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    380
    That's good to know.
    BCS are excellent systems that last.
    Good news
    IBIS WHITE S3
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    What sort of time scale you talking Mark about finding out about this.. I'd be a cert, I was gonna buy mine at the end of the month at full boona?
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,209
    Tomorrow hopefully mate. It might not happen but I will ask the question to them.....nowt to lose.
    Found this and makes for good reading.
    http://gfb.com.au/whats-new/latest-n...es-to-dv-t9351
    prt57's Avatar
    Dec 2006
    224
    I have the DV+ on my S3 along with a stage 1 and a Pipercross. Panel filter. The car goes very well IMHO and there are no DV noises that I can hear. The Mk 6 R forum is reporting some turbo flutter but not for me.
    The oem revision D valves are still prone to having a leak between the piston and the housing.
    If you have the DV+ make sure you lubricate the brass piston rather than the black plunger that some forums are telling you to do. When in doubt, read the instructions!!!
    Muzza80's Avatar
    Oct 2013
    Glasgow
    333
    The more I read the more I think this is the solution to any DV issues.
    Apparently even the later revision D valve with it's piston design still leaks, they did some bench testing and worked it out on a MK6 Golf GTI to be the equivalent of a 6mm hole in your intercooler! Yes you would still achieve peak boost with a 6mm hole in the IC but the turbo will be working much harder and hotter to get there and use more fuel at the same time.
    Mark If you can get these for less than £90 I'm in.
    Muzza80's Avatar
    Oct 2013
    Glasgow
    333
    Any word Mark? Would like to get one ordered ASAP.
    Cheers!
    2010 Audi S3 Sportback Black Edition TFSI Quattro
    prt57's Avatar
    Dec 2006
    224
    I ordered mine straight from AMD. Order from AMD via eBay to avoid shipping costs.
    Jkevs's Avatar
    Jul 2013
    Wales
    100
    Just been having a read through and i've got a 2008 s3 and I'm having a revo stage one on Saturday so would also be interested in the group buy
  1. High pitched noise when on high boost
    By Tim_Attard in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2013, 13:56
  2. Strange high pitched noise. HELP
    By Reesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2011, 13:23
  3. high pitch noise when driving? it gets higher pitched with engine revs
    By danonline in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2011, 19:23
  4. High pitched noise from rear speakers
    By Jay4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th August 2007, 14:50
  5. High pitched noise when starting from cold
    By ajek in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th November 2004, 15:00
