Sky InsuranceEM Tuning
Results 1 to 7 of 7
    May 2013
    Scotland
    Timing belt change
    Audi A3 2.0 tdi sportback 55 plate
    Guys.
    My timing belt it well over due, about 3 years over due although I've only got 65,000 miles on the clock. I am capable of doing it myself but fairly unenthusiastic about it! Looked at Audi, they change a cam belt for £439. Anyone know if that's just the belt they change or does it include the tensioner? Do i even need to change anything else other than the belt?
    While im here. How easy is it to check power steering connections and wiring on the rack, i'm getting intermitent dash warning....again!
    tdi-man's Avatar
    Jul 2009
    1,588
    water pump and tensioners m8
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    May 2013
    Scotland
    is that what i should change or what audi change?
    Keane's Avatar
    Jul 2013
    171
    The water pump ect is not a must, however it's recommended 👍 just had my s3 done and cost me £585 for cambelt, waterpump, and cambelt fixing kit which I believe is the tensioners ect
    May 2013
    Scotland
    Quote Originally Posted by Keane View Post
    The water pump ect is not a must, however it's recommended ������ just had my s3 done and cost me £585 for cambelt, waterpump, and cambelt fixing kit which I believe is the tensioners ect
    Did you get that done at Audi?
    Keane's Avatar
    Jul 2013
    171
    Yea that was with audi
    May 2013
    Scotland
    Going to give audi a call tomorrow, see what they say. Got power steering issues as well. Any idea how easy it is to see the steering rack wiring and rack connection?
  1. Cost of timing belt change A4 B6 TDI 130bhp
    By Andy D in forum General Chat
    Last Post: 28th February 2008, 08:50
  2. v6 timing belt change
    By bigdavie in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th November 2007, 16:48
  3. Timing Belt change
    By enda1 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th October 2007, 14:19
  4. Timing belt change
    By enda1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2007, 21:23
  5. timing belt change
    By danotto in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2007, 11:42
