JMB RetrofitsEM Tuning
Results 1 to 20 of 20
Like Tree4Likes
  • 2 Post By Boon
  • 2 Post By S.
Thread: Evans waterless coolant in an S3? Any experiences?
    s3facelift09's Avatar
    Dec 2012
    124
    Benefits Over Water-Based Coolants
    Eliminates Overheating
    Evans Waterless Coolants have a boiling point above 180°C and will not vapourise, thus eliminating overheating, boil-over and after-boil.
    Reduces Pressure
    Evans Waterless Coolants generate very low vapour pressures reducing strain on engine cooling system components.
    Prevents Corrosion
    Evans Waterless Coolants contain no oxygen effectively eliminating corrosion.
    Increases BHP
    Evans Waterless Coolants eliminate pre-ignition and detonation caused by overheating - thus improving combustion efficiency and delivering more power.
    Stops Erosion
    Evans Waterless Coolants prevent cavitation and eliminate liner and cooling pump erosion.
    Freeze Protection
    Evans Waterless Coolants freeze below -40ºC
    Non-Toxic
    Evans Waterless Coolants are proven to be Non-Toxic. Standard anti-freeze is toxic and known to kill pets.
    To go for, or not to go for?
    Veneeringman's Avatar
    Bazinga
    Aug 2010
    Back in the UK
    637
    Now that's interesting.
    2012 Misano Red RS3 / Bucket seats Heated front & Rear / Aluminium Styling Pack / Bose / RNS-E / Bluetooth / Mobile phone prep low / AMI / Reversing Sensors / LED number plate lights / Led interior light pack / VCDS / Cruise Control / Exclusive Inlays / Auto Lights & Wipers / 8.5J fronts / extended leather / Michelin Pilot super sport tyres / and a few other things
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    Who makes it?!
    sliced and LEE69 like this.
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Muzza80's Avatar
    Oct 2013
    Glasgow
    550
    Hmm, looks like good stuff!
    Dec 2012
    124
    Evans Cooling Systems UK, Swansea.. they have a good web-site with a large FAQ where everything is explained..
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    673
    If it does what it says 100% yes
    How much?
    IBIS WHITE S3
    Revo stage 2+ and loving it
    Muzza80's Avatar
    Oct 2013
    Glasgow
    550
    Quote Originally Posted by Marshy View Post
    How much?
    £65 for 5L
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    673
    If money's not a problem it'd be good to try.
    IBIS WHITE S3
    gixerson's Avatar
    Jul 2012
    Athens, Greece
    124
    Can't remember the exact brand, but i have tried waterless cooling liquid and ended up throwing it away.
    It was a pain to fill as you need to flush out the old coolant and let it dry,
    The car then ran a fair bit hotter with this stuff
    Absolute waste of time, money and effort
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Evans do say on their website that the engine will run a few degrees hotter.
    VCDS USER
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    Useful info here....
    No-Rosion Products Technical Questions and Answers
    It's either straight propylene glycol or a mix of propylene and ethylene glycol depending on which product you buy.
    It has a higher boiling point than water based coolants,and a lower freezing point,but also a MUCH lower specific heat capacity.
    Waterless Engine Coolant - PistonHeads
    Also straight propylene glycol is flammable when exposed to exhaust temps.
    Jan 2012
    473
    How will it increase performance exactly ....?
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    Quote Originally Posted by nluk100 View Post
    same probably as go fast stickers :D
    Sevv and s3facelift09 like this.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    From what I've read it allows you to run the engine hotter,which may provide some increases,but also to eliminate hotspots and reduce the onset of knock,but I still don't think any of that will persuade me.
    Jul 2013
    311
    nothing wrong with water and g12 has worked on millions of cars for years , if it was that revolutionary surely manufactures would make you use it ?
    Jan 2012
    SW London
    794
    Quote Originally Posted by s3_sid View Post
    Its the cost factor. £65 for 5L is a huge difference compared to normal coolant.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Jul 2013
    311
    Yeah but it only costs that much as they make a stupid mark up on it ! If they mass produced it their would be no reason drastically reduce the costs of production , and on high end cars if its for the life if the engine surely it would be cost effective
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,843
    If it's so good for the engine\environment & cost effective to boot, why aren't manufacturers falling over themselves to use it initially, instead of standard coolant? The same can be asked about internal engine\gearbox coatings like Slick 50, etc & coolant leak & rust inhibitors.
    There's usually a little known drawback not mentioned in the sales blurb for such things and I'd personally steer clear if you value your engine, unless\until it becomes manufacturer recommended.
    2009 A3 SB 2.0T DSG S line
    Oct 2013
    322
    They were pushing this in a major way at the NEC classic car show this weekend, expensive stuff, would need to be very good
    Dec 2012
    124
    Jay Leno has been using Evans for 16 years in his cars.. I hope they didn't just pay him to say that..
  1. Revo at Drivers in Glasgow?Any experiences?
    By IanL-S3 in forum Tuning
    Last Post: 13th April 2005, 16:28
  2. Any experience of A3 2.0T (3-door ideally) ?
    By A4_2point4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st January 2005, 12:48
  3. Superchips.....anyone had any experience?
    By ttandka in forum Tuning
    Last Post: 27th November 2004, 12:55
  4. Anyone have any experience with Abt chips?
    By plampine in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd July 2003, 22:36
  5. any one have any experience EXPORTING a car?
    By sfource in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 03:18
