[h=2]Benefits Over Water-Based Coolants[/h] [h=3]Eliminates Overheating[/h] Evans Waterless Coolants have a boiling point above 180°C and will not vapourise, thus eliminating overheating, boil-over and after-boil.
[h=3]Reduces Pressure[/h] Evans Waterless Coolants generate very low vapour pressures reducing strain on engine cooling system components.
[h=3]Prevents Corrosion[/h] Evans Waterless Coolants contain no oxygen effectively eliminating corrosion.
[h=3]Increases BHP[/h] Evans Waterless Coolants eliminate pre-ignition and detonation caused by overheating - thus improving combustion efficiency and delivering more power.
[h=3]Stops Erosion[/h] Evans Waterless Coolants prevent cavitation and eliminate liner and cooling pump erosion.
[h=3]Freeze Protection[/h] Evans Waterless Coolants freeze below -40ºC
[h=3]Non-Toxic[/h] Evans Waterless Coolants are proven to be Non-Toxic. Standard anti-freeze is toxic and known to kill pets.
To go for, or not to go for?
