Sky InsuranceVolks Autos
Results 1 to 9 of 9
Thread: ELM 327 OBDII
    Sep 2013
    Lincolnshire & Stockport
    152
    ELM 327 OBDII
    Hi Guys
    When I had my Ford I could use the bluetooth EML 327 OBDII no problems at all, since changing to the A3 (2010) I cannot get it to link up, it was a bit battered so thought would buy a new one as they dirt cheap, new one not connecting either, using torque on android had no probs before, do these not work on newish Audi's??
    John
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,158
    This works on my facelift 2009 A3, using Android Torque.
    ELM327 Bluetooth V1.5 OBD2 OBDII Auto Diagnostic Scanner Scan Adapter
    Sep 2013
    152
    yep practically same as mine....yet Torque will not find the bluetooth adapter, not sure why not tho
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    you should look if it's compatible with your car, as the newer ones aren't compatible with all cars as the older versions were.
    mine works on every car i've plugged it in, but my friend bought one and it doesn't work on most of the cars including mine.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,612
    I have a Wifi ELM, running Dashcommand on iphone5.
    Very hit and miss whether it connects or not.
    When it does, good piece of kit.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Sep 2013
    152
    Thanks guys
    V.A.G.erbond's Avatar
    Spooling
    Nov 2012
    Leeds
    129
    Is this still live. I've just Sussed out how to connect my BT ELM327 mini to dash command on my ipad. iPad is ios 7 jail broken but finally got it to work properly. Great app and diagnostic tool £6.99 on App Store and BT Dongle £7 on the bay.
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    527
    If Torque doesn't find your bluetooth adapter make sure the app is up to date.
    Make sure the adapter can be seen in the app.
    I had to uninstall and reinstall Torque to find my bluetooth as it worked then suddenly stopped.
    All Ok now.
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    Also with some mobile phones it has to be paired through bluetooth options. Pin is 0000 or 1234.
  1. obd2 elm 327 & iphone dashcommand?
    By coolevilangel in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th June 2012, 15:29
  2. ELM 327 OBDII which one to buy?
    By rasA4 in forum General Chat
    Last Post: 16th November 2011, 21:51
  3. OBDII Codes
    By imported_kbininger in forum Volkswagen and other VAG
    Last Post: 19th April 2006, 21:29
  4. Looks like APR have sorted the 2.0TFSI OBDII remap....
    By Cupramax in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2005, 11:26
  5. 2.0tdi ECU OBDII remap - It's here!!!
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2005, 14:06
