AH FabricationsBadger5
    waj
    Feb 2013
    10
    Audi A3 8P 2.0 TDI DSG
    Hi, i need some help regarding my car, basically
    just wanted to know if anyone else was having this problem, at first when i was putting my car in reverse it was making a thud noise coming from underneath my foot, got my mechanic to check it he said there was plah in ma wishbone arm bush front so changed both sides, got it done and the thuds gone but a slight jerk/knock when i was setting off in the middle of the engine at the bottom doesnt do it in any other gears. Wanted some help or advice in what the next steps are?? What to check?
    J8TT X's Avatar
    Jan 2011
    Leicester
    338
    engine mount?
    gearbox mount?
    both of mine were cracked and made a slight jerk when setting off.
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
    waj
    Feb 2013
    10
    My cars sorted now changed two front bushes on the wishbone arms, and 2 rear control arms and perfectly
    fine now thank god
    Sep 2012
    48
    So was that when you were choosing gear, like a little clunk? Mines quite clunky which im guessing is a similar issue to yours!
    waj
    Feb 2013
    10
    First it was only doing it when i put it into reverse if you put ya foot down a bit in reverse from set off it used to make a thud from underneath and then after i changed my front bushes it was making it slighthly in first but changed them too and now its fine
    Sep 2013
    38
    Wild shot here, but maybe DMF?
  1. Flywheel and turbo on Audi A3 2.0 tdi DSG
    By brettsh555 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd February 2013, 17:06
  2. audi a3 2.0 tdi dsg tapping when idle
    By sam2681 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2012, 18:25
  3. HELP needed..54 plate audi a3 tdi dsg
    By audi_a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th July 2010, 03:10
  4. Audi A3 S LINE 2.0 TDI DSG 140PS
    By skyliner34 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2010, 19:51
