Volks AutosSky Insurance
Like Tree1Likes
  • 1 Post By MrLapou
Thread: OBD2 Question
    Aug 2012
    Aberdeen
    42
    OBD2 Question
    I had posted this in the Volkswagen bit but I guess it applies to my A3 also as it will be same system etc.
    "General query, looking for some info as to what extent you can use OBD2 devices with newish audi/volkswagens.
    More specifically basically just looking for something to reset the engine management light. Will OBD2 scanners like the type available on amazon etc. be able to do this or will it have to be the rosstech CANbus cable etc.
    Car to be used on is a Golf R32
    Cheers"
    Any help would be greatly appreciated
    Chris
    27,129
    Readers may well remove lights, but to find out the causes & check everythings working as it should, VCDS is definitely the way forward, its just allot more comprehensive, reads, scans the whole car, clears all codes, measures, tests, recodes, lots of things that are of use to many different vehicle owner.
    Get yourself VCDS mate, nobody ever regretted it that I'm aware of
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    VCDS defo worth the extra money...
    Readers may well remove lights, but to find out the causes & check everythings working as it should, VCDS is definitely the way forward, its just allot more comprehensive, reads, scans the whole car, measures, tests, recodes, lots of things that are of use to many different vehicle owner.
    NHN likes this.
    Aug 2012
    Aberdeen
    42
    NHN are you still selling them. Will need to get some funds together I think.
    27,129
    I am & have stock to post out for next day delivery
  1. Quick question obd2 cable
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2010, 08:43
  2. The Big Question - War
    By Moresauce in forum General Chat
    Last Post: 28th February 2003, 16:10
  3. Drilled or Slotted thats the question?
    By Tweaky in forum General Technical / How To
    Last Post: 23rd February 2003, 00:21
  4. Couple of questions for admin...
    By MickHumphrey in forum General Chat
    Last Post: 2nd January 2003, 17:04
