Results 1 to 24 of 24
    Oct 2012
    95
    Steering wheel judder - S3 (2007)
    Looking for some opinions if possible.
    Car is booked in to be checked out next week, but just curious as to what the problem is...
    Recently had new front discs and pads (OEM) fitted. Bedded in carefully.
    I am now getting wheel judder at a steady 80-100 mph, becoming more noticable when braking.
    First thoughts were a warped disc, but its not only happening when braking, so then turned to wheel balancing. Had the four wheels balanced, and it remains the same. I also had the fronts swapped to back, and the car is behaving exactly the same.
    Now thinking it could be a suspension problem. Are there any common faults with the S3?
    Jan 2012
    478
    Had the same on mine - turned out to be warped discs (and I bedded them in correctly too!)
    Oct 2012
    95
    Cheers nluk100, was it happening even whilst not braking?
    Oct 2012
    95
    and were your discs changed under guarantee?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Wheel balancing needs doing or buckled wheels.
    8P2 S3
    Oct 2012
    95
    As said above, just had the wheels balanced. Given the fact its is behaving identically after switching fronts to back, I don't think its down to a buckled wheel(s), although its a possible.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by shinsplint View Post
    Sorry, missed that. Defo have a look into them being buckled, it may be that more than one is damaged.
    8P2 S3
    Oct 2012
    95
    Cheers Staz, any idea where I could get them checked for buckles?
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,406
    Follow Brodster On Twitter Add Brodster on Facebook
    I had exactly the same on my 2012 S3...............after a year I had pads and discs replaced due to being warped....now 3 months after that I started to get a really bad wobble under braking so I thought the discs had gone again...........very strange seeing as I use the engine and gearbox to do alot of the braking when at speed. Now I contacted one of my associates at Brembo and he suggested that I take it out and give it a good old thrash on the brakes - heavybraking, keeping my foot slightly on the brake pedal for a few hundred yards at a time etc etc as he suspected glazed pads n discs. This is exactly what I did for a about a week and now my brakes are amazing again. No wobble whatsoever under braking anymore so whatever was wrong was cured whilst doing what he said. Hope this helps.
    Have you got aftermarket wheels fitted??? If so are there spigot rings fitted???
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Any place that does balancing mate. You'd think that it's not possible to balance a buckled wheel but apparently it is! If they specifically look they should be able to see it.
    You can get a wheels refurbed to repair minor buckles, which includes a full repray and everything. You're looking at over £300 for the 4.
    8P2 S3
    Oct 2012
    95
    Cheers lads,
    Brodster, i'll give that a go. Well I have already gave it a bit of stick but not as hard as you described, so worth a try I guess.
    They're standard wheels, and I suppose at 7 yrs old they could have minor buckles. Now back to my previous question... do I change the wheels lol !
    Oct 2012
    95
    Update:
    My regular mechanic is also baffled by this.
    You can brake quite hard and sometimes there is no judder at all, but when feathering the brakes it is much worse. At 80mph + there is judder even when driving steady and not braking. This would suggest it is nothing to do with the brakes. Mechanic checked the suspension bushes which are all fine. Some minor play in one of the bushes but apparently not enough to cause problems.
    Tomorrow he's replacing the discs under warranty, although neither of us are convinced it will sort the problem.
    I previously had the four wheels balanced which made no difference, apart from my wallet.
    I'm thinking a wheel buckle of any kind would cause continuous vibration though the steering column, not intermittent.
    Any ideas / possibilities appreciated !
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    My wheels were buckled and the vibration only occured at certain speeds.
    8P2 S3
    Oct 2012
    95
    ok, going to get the wheels looked at once i've had the brakes changed. Cheers.
    Reload's Avatar
    Bird is the Word!
    Jul 2010
    Midlands
    367
    Quote Originally Posted by Staz View Post
    What he said, I had the same issue at 70mph plus, even when driving straight and stay. Turned out both front alloys were buckled, fortunately replaced under warranty
    S3 8P2 Ice Silver, RNS-E, Bluetooth, iPod connection, Adaptive xenons, black styling pack, sunroof, privacy glass
    Mods since owned: Milltek Resonated TBE, Neuspeed P-Flo, Loba HPFP, Sachs Clutch with Loba SMF, Unicorn Motor Developments custom remap, brakes + suspension upgrades, LEDs internal and external, more interior kit
    c_w
    1,061
    In the OP the wheels were balanced. What bugs me about anybody who claims to be tyrefitter is despite you going to them with an issue they will just blindly balance them and not inspect the wheel tyre as they balance them. A buckled wheel could have been diagnosed then and not on the 2nd or 3rd attempt at balancing them! I only take my wheels to Wheelbase now who have a very expensive (and new) balancing machine and it is always spot on.
    It sounds to me like you might have two issues, one is a balance issue (even good wheels/tyres sometimes it takes a couple of times to get balancing right depending who you use) and the other is slight brake judder. The wheel wobble is then exacerbated by braking at high speed. If the brakes were smooth it would not add further to the wheel wobble you feel when off the brakes.
    The brake judder is likely pad desposits and like in that post further up from Brodster it might be a case of re-bedding them in.
    There is a small chance it could be a lightly binding brake caliper.
    Wheel wobble is always balancing (or wheel/tyre issue) or brakes (when braking). It's never suspension parts IME, so don't go throwing a load of money at it with new parts because someone ran out of ideas.
    Nov 2012
    Bath
    50
    Try checking the front hubs for runout. Had a vw garage replace dics and pads a few years ago and i had loads of vibration and judder on braking. Turned out they had damaged the hub when getting then bearings out. They replaced the discs and pads three times to try and sort the problem but when i replaced the hub all was ok.
    2012 S3 SPORTBACK Panther Black
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    I get a judder around 80mph but not when breaking. Recently had tyres fitted and balanced but no change. I'm thinking it could be the spacers I have fitted. Taking them off this weekend to check.
    Oct 2012
    95
    Update:
    The saga continues...
    Last week I had the four wheels refurbed and checked for buckles - all perfect. So back to the garage today...
    Mechanic has checked over it all once again. Says there are slight cracks in the lower bushes, and suggested to change these. As I reminded him though, my concern was that the problem only came about after he changed the discs and pads last year. He is therefore ordering replacement brakes under warranty which will be fitted next week.
    I couldnt see the point of throwing money at new bushes, if it doesnt solve the problem...
    What are your thoughts?
    So far then:
    All wheel balanced more than once.
    Tyres all good (matching Michelin PS3).
    Still getting the wheel wobble after 80mph, (braking or not), which gets worse when braking down.
    Another ride in to work today in brutal headwinds for no reason lol
    c_w
    1,061
    Same tyres fitted to the front? Could be some tyre runout. Also depends who's balancing the wheels, I've given up with most places now and will pay extra to use a local tyre place near me that uses top notch modern equipment.
    Oct 2012
    95
    Quote Originally Posted by c_w View Post
    The four tyres are michelin PS3. I've tried swapping them round, and the car behaves exactly the same. I'm 99.9% sure its not a wheel problem.
    Nov 2012
    Bath
    50
    Still think you should check the hub run out. Its dead easy with the wheel off and using a dial gauge. Its a 5 minute job for a mechanic.
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    how you getting on with this?
    www.SubZerosystems.co.uk - IT Consultancy
    Oct 2012
    95
    Quote Originally Posted by klauster View Post
    Had he brakes changed under warranty and its much better. Not perfect but im happy wih it.
  1. 2007 Audi S3 2.0 TFSi Quattro - Sat Nav, Flat Bottom Steering Wheel
    By Plastic_Badger in forum For Sale/Wanted - Audi Cars
    Last Post: 5th May 2013, 11:24
  2. rs6 steering wheel on 2007 s3
    By djlazyp in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th March 2010, 16:30
  3. Tiptronic steering wheel
    By TheTonsta in forum General Technical / How To
    Last Post: 31st August 2003, 18:57
  4. pc steering wheels
    By badbaz in forum Video Gaming
    Last Post: 10th August 2003, 14:33
  5. Steering Wheel Remtoe for stereo?
    By AutoMatt in forum In-Car Entertainment
    Last Post: 8th August 2003, 08:07
