Chris NottMonster Motorsport
Results 1 to 24 of 24
Like Tree4Likes
  • 1 Post By dexx913
  • 1 Post By Artimus
  • 1 Post By bez101
  • 1 Post By NHN
Thread: HELP! something is wrong...............
    Jun 2013
    Bristol
    85
    Visit dexx913's Instagram Channel
    Guys,
    lastnight i swapped my wheels over for some mercedes monoblocks the car is sitting very low and i will be getting the coilovers raised up ASAP as it looks ridiculous this is off subject however it does give you a bit of detail as to what has been done to the car since the problem
    now to the PROBLEM!
    I started the car up lastnight after the swap of the wheels i had the lights on for a while whilst i was changing the wheels.On the start up the engine seemed to be juddering a bit and sounding not to healthy as it was cold i assumed this is what it was and left it until this evening as i did not drive to work today!
    SO i started it up this evening and the engine is juddering ALOT, Aswell as once firing cutting out after 10 seconds a couple of times, the rev gauge is not smooth and seems to be jumping up on idle and very unresponsive.
    Its a 2010 1.4 tfsi it had its First MOT last month and a full service and everything was fine....
    Does anyone have any idea what this could be
    HELP!
    Thanks in Advance Dec
    Oct 2013
    25
    Are you sure you haven't broken the sump (oil pan) which is located underneath the engine due to the car being too low?? my car had the same problem when I broke my oil pan last week due to a raised drain in the road whilst there was road works going on, lucky I stopped the car and found the problem otherwise the whole engine could have got ruined.
    Jun 2013
    Bristol
    85
    it is ridiculously low but it hasn't been moved at all really with the new alloys on! and wouldn't there be a leak from the sump? as i cant see any fluids?
    will there be any other tell tell signs if it is that?
    thanks
    Adam88 likes this.
    Oct 2013
    25
    If it has cracked it then yeah I guess oil will be leaking.. Check your dip stick see if it has oil?
    Oct 2013
    25
    Also is the car parked on a slant with low fuel?
    Jun 2013
    Bristol
    85
    just checked again no fluids and there is oil there its got low fuel but it isn't on a slant, the exhaust also seems to be spluttering?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    scan for fault codes
    TDI140's Avatar
    May 2011
    1,364
    Fuel filter if low fuel coudl be sucking in dirt ???
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Jun 2013
    Bristol
    85
    dont have vag com so cant scan for faults....
    fuel is low but not that low still have about 70 miles in the tank,
    could it still be the fuel filter?
    Thanks again lads
    27,121
    You haven't touched the maf or any connectors have you?
    Jun 2013
    Bristol
    85
    no Nige absolutely nothing,
    its literally just cam over night the vehicle wasn't even used today its so out of the blue its unreal!
    Cheers dec
    27,121
    Remove battery leg for 10 minutes, then try again, it doesnt make sense if you only did the wheels.
    Jan 2012
    SW London
    794
    As NHN said, ecu reset seems to be the way forward. Did u have the car running on idle for any amount of time? I do this sometimes when im cleaning my car and its always a sluggish lil bar sterward for the first mile or two. Never had misfiring issues tho
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Battery so weak\low the alternator is having a job charging it from such a puny engine? Give it some hoof or put it on a charger.
    NHN likes this.
    2009 A3 SB 2.0T DSG S line
    Jun 2013
    Bristol
    85
    Guys just a quick update....
    local garage thinks it could be the coil pack on a petrol ? is this common
    he hasn't had a look at it YET just what he thinks it sounds like
    Any idea for the price I should be looking at for the repair
    bez101's Avatar
    Jul 2008
    8,530
    THINKS ?
    tell him to scan it if its a pack it will show missfires
    yes they are common and easy to fit yourself but buy genuine the gsf euro can and do fail fast
    and cost around £40
    NHN likes this.
    Jun 2013
    Bristol
    85
    yea thinks I just had a chat with him over the phone pal!
    hasn't actually scanned it yet
    cheers bez
    27,121
    VCDS is handy for times like this
    Artimus likes this.
    Jun 2013
    Bristol
    85
    i no nige! im going to have to invest it would of helped a lot......
    i have however come home to the dreaded oil all over the drive way :'(
    im guessing this is BAD news?.....aswell as the rough idle
    27,121
    Oil all over drive, urm its shxt itself, very strange.
    Where's it come out from?
    Jun 2013
    Bristol
    85
    literally look like its sh@t itself! lol
    possibly the sump....but it just does NOT make sense as it hasn't moved much since putting the wheels on!
    if it is the sumps isit an expensive repair ?
    27,121
    I'd be extremely more worried about the fact it was running bad & now its crapped itself, unless you dropped or lowered the car onto the sump, then I just cant see how that's happened.
    Jun 2013
    Bristol
    85
    thats my theory i cant see how it would of happened!!
    so nige any idea what you THINK it could be from it juddering,loss of power and now it crapping itself what do you think?
    the mechanic is having a butchers tomorrow!
    and i cant stop bloody thinking about what it could be lol
    27,121
    TBH mate where did the oil come from, that's the key here.
  1. need help fast whats wrong now?
    By Tim_Attard in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2013, 13:52
  2. Help- Jump leads wrong way! audi a4
    By richie301187 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th April 2012, 22:00
  3. Help SOMETHING is hanging off my car!
    By Pan_fried_chicken in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st January 2010, 20:38
  4. please help wrong time
    By sbanjac in forum Classic Audi Forum
    Last Post: 14th June 2004, 13:20
