Sky InsuranceEM Tuning
Results 1 to 10 of 10
    Jun 2013
    104
    problem with forge twin take s3
    Had this kit fitted over the weekend and i noticed last night that when you rev the engine in neutral and the revs drops just below 1k the car nearly stalls? cold this be a maf issue?
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Nearly stalling sounds like it might be a MAF issue, but it should be idling at 800 anyway, so must be quite a drop?
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Jun 2013
    104
    its idles fine its just when you rev it up the the revs drop down it about stalls
    JamesS4cab's Avatar
    Mar 2008
    1,122
    Check that you got the MAF in the correct way round when you fitted it as its directional and an easy mistake to make........
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    Jun 2013
    104
    Quote Originally Posted by JamesS4cab View Post
    surely it can only fit in one way? Going to check the maf later on
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    675
    If the maf is the correct way round I'd double check the hose on to the turbo is seated correctly and not lifted on one side.
    IBIS WHITE S3
    Revo stage 2+ and loving it
    TDI140's Avatar
    May 2011
    1,350
    Got to be a leak somewhere one hose must be loose
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    675
    Yeah that's my thoughts too.
    it must be getting unmetered air so you'd think it has a leak after the maf.
    JamesS4cab's Avatar
    Mar 2008
    1,122
    The MAF can fit in either way, but one way in it works perfectly, and the other it doesnt work properly and the side affects are generally as you describe. I would also agree with the others that it could be a boost leak. I split a small boost house near the DV and that caused same problems but when i opened the bonnet i could hear it leaking.
    JamesS4cab's Avatar
    Mar 2008
    1,122
    One other thing - was the Forge new or not? If its s/hand, is the filter clean? Has it been over oiled as that can causing "breathing" issues.............
  1. Forge twin take canisters Clean
    By ilim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th June 2012, 10:39
  2. Forge Twin take.
    Last Post: 19th April 2012, 12:40
  3. Update! Forge Twin Take
    By gaz m in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd April 2010, 16:37
