JMB RetrofitsBadger5
Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By NHN
  • 1 Post By coxy8329
  • 1 Post By JJ.Foulds
Thread: Bad Battery? or something else
    Mar 2013
    161
    Hi,
    my car failed to start yesterday and had to be jumped, i didnt leave any lights on etc...Drove home fine
    It started this morning but struggled, pretty sure the alternator is fine. Maybe just a weak battery?
    Gonna get it checked when i have time, do anywhere do free checks?
    and if i get a new battery is it a straight swap or does anything need resetting?
    car: Audi A3 2.0 TFSI Quattro SLine 2007
    appreciate it if anyone can answer these, Thanks
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    491
    I had same problems a few months ago, replaced the battery and it cured it.
    Nope can be a straight swop - i payed around £35 for a Varta battery and it was just a case of removing old, and putting new in.
    Time and date will need resetting, and on first start i think the ESP will show fault (does on mine) then it clears.
    Jonny.
    Mar 2013
    161
    Quote Originally Posted by Jonathaan View Post
    Jonny.
    thanks for the reply
    did you buy the battery online?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Prob on original factory battery. Which in that case it'll be time for renewal.
    SPARTAN91's Avatar
    RED FIVE STANDING BY
    Zookeeper Champion
    Nov 2012
    NORFOLK
    412
    I replaced my 5 year old battery the other week as I had the amber symbol come on in the DIS saying low charge.The light hasn't gone out with a new battery so it went into my local dealer yesterday turns out all is OK with that side of things and it's all down to a fault with the instrument cluster so only fix for that is a new one.
    58reg 2.0tdi 140(WAS) S-line Monza Silver withSUPERCHIP BLUEFIN
    S3 front grill/gloss fog light surrounds/rnse/gloss gunmetal wheels/EZ front spliter
    27,096
    Varta Ultra Silver Dynamic, best battery for the 8P & not expensive either
    Search forum for this, as I've detailed part numbers various times.
    maikysupra likes this.
    Feb 2013
    Grimsby
    1,094
    got mine for like £70 delivered, and its been great. and such an easy change, and it was more powerful than the battery i had it before!
    05, A3 8P 2.0TFSI Quattro
    Mar 2013
    161
    would have gone for that but too late now, already ordered
    this is decent enough i think
    cost £57
    Feb 2013
    Grimsby
    1,094
    'the S3 is perfect for older and more basic vehicles with fewer electrical consumer devices'
    Erm, arnt AUDI EVERYTHING is electrical? lol, i was under the impression they are heavy juicers.
    Feb 2013
    Grimsby
    1,094
    Quote Originally Posted by ENZO View Post
    cost £57
    THE BOSCH
    • Amp Hours: (Ah): 53Ah
    • Cold Cranking Amp: (CCA): 470cca
    THE VARTA
    Battery Capacity [Ah]: 77
    Cold Cranking Amps (CCA), EN [A]: 780
    The VARTA is significantly better for only £13 more, if i was you id be asking for a change of order.
    Mar 2013
    161
    thanks guys
    i shouldn't have rushed into it, just needed a battery asap
    requested a refund for the bosch and then i order this:
    not sure if this one fits? i found this exact link from another thread n here
    E44 Varta Silver Car Battery 77Ah (577400078) - Car Batteries - Varta Car Batteries
    May 2013
    London
    52
    I have the same car with the same age. What's the easiest/best way of checking if it's on it's way out before it's too late?
    coxy8329's Avatar
    Nov 2011
    Hampshire
    166
    Yes that should fit, fitted one in my A3 last week. A much better battery that the original.
    ENZO likes this.
    Audi A3 Sline 170 2.0 TDI
    Mods Done
    RNS-E mkII fitted, Tinted Repeaters, Center Armrest,
    LED Interior Lights, Cruise Control, LED Number Plate Lights,
    VW fan windshield washers, S3 Pedals, Metal Footrest,
    DPF & EGR delete, Unicorn Remap, De-badged the tailgate.
    With DPF Without DPF
    Feb 2013
    Grimsby
    1,094
    Quote Originally Posted by geforce189 View Post
    A local garage shud do a free battery check, takes most part of 30 seconds and will give a voltage readout. should be around 14v I THINK.
    geforce189 likes this.
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    491
    Bought it from a local car shop near me, looks like youv sorted this problem owt now tho? Be sure to update us when you come to fitting the new one (y)
  1. new key, battery or something else?
    By munchkincoupe in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th May 2013, 09:01
  2. MAF or something else?
    By StraightSix in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd July 2010, 11:19
  3. Megs wheel brightener or something else....
    By S3 Rav in forum Detailing
    Last Post: 28th February 2010, 18:29
  4. Something else i've just noticed about the new VED bands!
    By Nickynibbles in forum General Chat
    Last Post: 22nd September 2008, 13:11
  5. battery or something else?
    By imported_Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2005, 15:23
