Monster MotorsportChris Nott
    Jun 2013
    2009 A3 sportback facelift s.line led rear light problems
    Hi all, I have a 2009 'face lift' sportback tdi s.line with the led rear lights fitted as standard.
    My problem is that the smaller rear light, which is on the boot lid seems to have developed a fault.
    Some times the led tail light part will work and some times it dosent. There is clearly a fault some where but I could do with a bit of help finding it.
    I even ordered a replacement from audi, which made no difference, so at least I know the fault is not with the light unit its self.
    Does any one have a wiring diagram?
    Thanks in advance.
    27,097
    Check the boot hinges for any frayed/damaged wires, remove bootlid trim & look inside aswell, check connectors for any corrosion.
    Jun 2013
    Thanks for the suggestion, checked all that. It all seems ok.
    Is the light on the boot lid linked to the main light in any way?
    After taking the main light apart, it seems to work for a bit, so Im guessing that the problem could be coming from that area?
    Any one have a wiring diagram?
    27,097
    The inner led ring is linked to outer on factory fitted & any I install.
    Jun 2013
    do you know which are the link cables?
    27,097
    Just check the wire colours, should be same either end.
  1. Sportback LED Rear Lights (Fitted by itwasntme187)
    By chrisb72 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2014, 18:14
  2. LED rear lights problem
    By adrenalin84 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th May 2012, 05:55
  3. Coding For A3 Sportback Led Rear Lights Retrofit
    By Stampie in forum VCDS (formerly VAG-COM) forum
    Last Post: 16th September 2011, 20:56
  4. Sportback 2009 Led rear light wiring repair/ harnesses ?
    By Lings in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd May 2011, 15:04
  5. Sportback LED Rear Lights
    By PTTM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2009, 19:37
