The Governor
I was mooching about under the car yesterday for no good reason really and I noticed that the underseal below the sills has come away just behind the front drivers wheel, just ahead of the jacking point.
I'll stick a photo up when I get home, but it's like it has peeled back somehow, and there is a bit of the metal underneath protruding out (subframe?).
First question, should I worry about it really, or just leave it?
If the consensus is to do something, is there a way I can seal up the small area affected? I don't especially want to have the whole treatment redone along that side fo the body as I assume it would be expensive...
Could I/should I just rub it down, and seal it with Hammerite?
Roy
Roy
