EM TuningChris Nott
    Jun 2010
    217
    Thumbs up S3 Cooling / Radiator Fans issues questions
    This topic has been covered extensively i do realise, however in the many many, MANY of threads i have there really isn't much information or definitive answer on a few things that i am wanting to know, and if there is i apologise.
    Few questions; relating to my 2007.5 S3 8P.
    After-off fans - how often does this occur as our climate here in Sydney even after driving in 33 degree heat in traffic on saturday my fans do not stay on after the car is off - ever. Is this normal, or something with the controller, relay, or coolant temp sender?
    Engine temp is fine, no issues with airconditioning what so ever either.
    I do also notice, A/C on driving on freeway on a 20-25 degree day that my temp sits below 90 degrees which is unusual, or normal?
    Coolant temp sender is still factory i assume, has had major service, but not sure if thermostat was done. Car hasn't over heated ever before or caused any cooling issues.
    Did get a vagcom error for the fans first time the other day, resetted and hasn't returned so i am very confused.
    Any help or direction appreciated as unfortunately its all here-say over here with not much first hand experience.. i dont like the answer of 'replace them' as they work fine, just curious if its module or something else i am missing here.
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    807
    Temp should be bang on 90 check it with vcds/vag com
    Growing old is mandatory, growing up is optional
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,071
    Thermostat stuck open mate, cheap part but an alternator out job..
    Had the same issue with mine sat on 90 in traffic but dropped as soon as I got moving. Might sort out the fans as well as the engine is letting coolant in before it's warmed up
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Jun 2010
    217
    Quote Originally Posted by OVRA3 View Post
    The thing is, it doesn't always drop when moving. Happily sits on 90 degrees also just depends on weather/and driving freeway/city.
  1. Radiator Fan Issue
    By A3-8PA in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2013, 09:21
  2. 2004 a4 radiator fan/ cooling issues, help!
    By Andylewis in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd January 2013, 14:50
  3. 99 S3 Cooling (radiator) Fans On/Off Constantly
    By OW29 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2012, 21:43
  4. Cooling fan issue
    By bengal in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2012, 11:35
  5. Question on 2.0tdi sportsback radiator fans
    By JasonM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2006, 18:56
