Monster MotorsportChris Nott
    May 2013
    245
    No response from accelerator? Any ideas?
    So I get in, start the car and stick it in reverse (DSG gearbox) on a slight incline, release the brake and hit the accelerator... car rolls down! I try again, and once more the car simple rolls down with no feedback from the accelerator and no reverse motion whatsoever. At this stage I'm inches from the car in front and alarm bells are ringing so I stick it in P and hit the accelerator to see if it revs, and nothing at all, just idles.
    Turn her off, switch her back on and everything's fine again Any ideas what on earth went on? It's a 55 plate DSG if that's of any relevance.
    27,089
    Does the dis show you changing from P, to R to D etc?
    May 2013
    245
    Ah crap, I didn't actually check when it happened. However even whilst in P, I got no feedback when the accelerator was pressed.
    Hasn't happened after that, I've tried starting car from cold again etc and it still seems fine now.
    27,089
    If it happens again, then check the dis for the change in drive modes.
    May 2013
    245
    Will do if it happens again, thanks.
  1. Whining noise when accelerating, any ideas?
    By Nuno_rules in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2 Days Ago, 20:03
  2. 2.0tdi 55 plate (Throttle Position Sensor) A3 DSG no response from accelerator
    By Andre Poleski in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th August 2012, 16:22
  3. Strange vibration under full throttle acceleration. Any ideas?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 15:21
  4. Strange sound under acceleration - any ideas?
    By MikeA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2009, 23:34
  5. Fascia for 2001 S3, any ideas where from?
    By pafitoui in forum In-Car Entertainment
    Last Post: 10th January 2004, 15:45
