Volks AutosAH Fabrications
    Sep 2013
    Bradford
    13
    Coilover question
    Hi all. I have a 2007 S3 and am trying to work out why 2wd coilovers are different to the 4wd ones? I think the s3's are a 55mm front strut but am happy to be corrected?
    Also I've seen 55mm coilovers for sale that only say 2wd and don't know the difference?
    Sorry if this seems like a stupid question!? Haha!
    thanks for any help
    Sam
    Feb 2011
    Plymouth
    1,120
    The 2wd has a spring separate to the shock on the rear where as the Quattro has an all in one shock and spring on the rear like any normal front coilover
    Sep 2013
    Bradford
    13
    Really? I thought they were the same set up as the mk5 r32 I had with was a seperate spring cup on the rear bottom arm and seperate shock?
    Feb 2011
    Plymouth
    1,120
    I'm pretty sure thats how it works, i'll be corrected if I'm wrong though. It was the case on the 8L's for definite
    Dec 2011
    234
    The s3 is 55mm front strut and the back have a spring and shock separate the same as the r32
    Sep 2013
    Bradford
    13
    So is there any difference from the ones advertised as 2wd and those advertised as 4wd? Maybe just spring rates? I can't see how they would fit any different or am I missing a fundamental difference? Haha.
  1. coilovers question
    By A3simon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th December 2006, 13:24
  2. Coilover Question
    By ScottyBoy in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th June 2006, 23:04
  3. fk coilover question
    By 1mran in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2006, 17:01
  4. Lowering on coilovers question
    By imported_Turbopaul in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2005, 17:06
  5. coilover question
    By cyuen in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 13:25
