JMB RetrofitsChris Nott
Results 1 to 29 of 29
Like Tree7Likes
  • 1 Post By S3_Jacko
  • 1 Post By H17YD L
  • 1 Post By Boon
  • 1 Post By Keane
  • 1 Post By S.
  • 1 Post By S.
Thread: MTC Cold air intake... Installed today with pics
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Hey guys... Just a short thread on this, installed my MTC cai today with the ITG filter kit... Great piece of kit for the money and fits together nicely..
    Matthew who makes the kit is a very nice fellow, very helpful. Hes just started his own company recently making these kits and they come in a few different colours.. theres a few threads going around at the moment, but heres mine, as hes being doing them a wee while and the kits have progessed since he 1st started doing them...
    Completed installation in just over an hour.. The hardest parts of installation is getting the old engine cover mounts removed from the top where the new heat shield is to be installed, there a 2 10mm bolts underneath to be took off 1st, then they just unscrew.. A good set of mole grips is also required to removed some of he spring clips but come out relatively easy if you have the right tools.. I'm also going to get a small jubilee for the end of the recirculation pipe to just firm it up that wee bit more..... Had to trim some of the pipework at the filter for a nice fit, but obviously this will vary with each filter..
    1st impressions are good... complete change in low end delivery and now feels a lot smoother with a nice sounding bit of suction.. Anyway i'm a happy camper, now for the uprated DV and TTS cover...
    If anyones interested in these kits, contact Matthew via txt on 07976469664 for info and prices on your own car...
    Enjoy the pics.....
    Start of Job....
    [IMG][/IMG]
    Where extra jubilee will be fit for extra tightness...
    [IMG][/IMG]
    Snug fit after some pipe trimming....
    [IMG][/IMG]
    OCD kicking in having to get everything level... Even the name ha
    [IMG][/IMG]
    Finished Job....
    [IMG][/IMG]
    R90 STL likes this.
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    Feb 2011
    Plymouth
    1,140
    looks good, blue hoses would have finished that off though!
    Jan 2012
    SW London
    794
    Get that bay cleaned!
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Dec 2012
    243
    Very nice mate! Just watch where you have cut the bottom elbow shorter. I did the same but found the filter neck rubs on the hose bellow. So I swapped it round and just have the filter squashed up against the headlight
    S3_Jacko likes this.
    2010 Condor Grey S3 Sportback S-Tronic. 354bhp 414ft/lb.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Quote Originally Posted by smurfworth View Post
    I quite like the stealthy look.. i've got the black n white interior so it kinda follows that theme through.. ha!
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Quote Originally Posted by Sidhu88 View Post
    Anno man its shocking.. its on the soon 'to do' list
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Quote Originally Posted by H17YD L View Post
    Thanks... I noticed that... I pulled it up slightly away from that hose before I tightened that last jubilee, so its kinda floating in mid-air now... was still touching the fuse box casing so a quick push into the actual filter at that side, took it away... not touching anywhere at the moment so happy
    Boon's Avatar
    Sep 2012
    South East Kent
    411
    I can't help but think why this works better???!!!
    All that warm air being sucked in...
    To me the very first pic as stock would be the best solution to cold air intake with smoother pipe work and a high flow filter all sealed from the engine bay...
    Yeah looks good though!! Although it needs the engine cover back on
    NHN likes this.
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Keane's Avatar
    Jul 2013
    219
    Looks awesome !
    27,096
    Looks are nothing unless its actually effective, given its hidden under the bonnet 24/7, I couldn't care if it looked a real mess under there, just needs to be functional otherwise its a waste of money, which allot of aftermarket filters & intakes actually are in comparison to oem.
    It needs testing really to see what differences it makes against others including oem, otherwise its just a placebo.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Quote Originally Posted by Boon View Post
    Once the enigne covers back on there wont be a lot of warm air swarming around that bay... If you look at the bottom pic, the vent where the std duct was isnt blocked, it will still be loading that area with cold air + in addition to this, the cover behind the fog grill has been removed and there will be extra cold air coming up through the fog cover aswell... If i'm bored 1 day, I might even go the the trouble of fabricating a shield from the engine...
    Noticed a difference with the low end delivery right away Nige... far smoother response at the low end... Whole engine feels a lot smoother with this, especially when removing accelerator after giving it the beans (Slightly) no aggresive judder, just nice smooth deceleration... Functionality over colour coding and looks for me and its very much a functional part.... i'm impressed!
    27,096
    Are you sure its not a placebo :P
    Glad you're happy with it, I think as Boon has noted, shielding the filter from the box & engine heat, will do you nothing but good fella, open like that just makes its effectiveness less.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Do ya know... I was asking myself if it was a case of mind playing tricks... but the most notable difference is defo when you take your foot off the go pedal... no aggressive deceleration... it defo....defo feels a lot smoother haha....
    prt57's Avatar
    Dec 2006
    243
    Looking good, please can you tell me what tool you used to remove the hose clips on the original TIP? It is the hose clip down at the bottom, below and to the right of the master cylinder.
    Thank you,
    Peter
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Quote Originally Posted by prt57 View Post
    Thank you,
    Peter
    Hi mate, thanks.... I just used a big set of mole grips, clamped over the top then screwed the grips tighter with the adjuster at the bottom and worked a treat, came off very easily..
    prt57's Avatar
    Dec 2006
    243
    THanks for the speedy reply.
    Would this tool do the job without skinning my knuckles?
    BGS - Flexi Ratchet Hose Clamp Pliers For Fuel & Coolant Hose Clips 630mm Bowden | eBay
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    I dont know what that tool is mate.. never seen 1... you can get mole grips outta b&q or the likes for a lot cheaper than that.. just google mole grips and give them a view
    manor13's Avatar
    Aug 2013
    West of Lothian
    431
    I would shield the filter and at the back( the two mount bolts that are hard to get) and at the front, when I had my dbilas fitted to my ed30 the heat in the bay was damn hot @ crail would have to get the bonnet open between runs.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    yeah heat shield would be nice, but once the car is moving there's not too much heat there.
    i've made custom one from aluminum sheet, now i have new idea of making heat shield filter box out of carbon fibre...
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Quote Originally Posted by manor13 View Post
    I'll probably just fabricate a shield between the engine and filter... I still want to include to standard intake duct aswell as the cold air coming up through the fog grill.. what do you think the best material would be to use.. a thick plastic?
    Jul 2013
    311
    you dont have to worry the same as a naturally aspirated car as its going to be heated up alot hotter when it does though the turbo and once its gone though the intercooler will get it to within a few degrees of ambient hopefully
    Boon's Avatar
    Sep 2012
    South East Kent
    411
    Quote Originally Posted by s3_sid View Post
    i beg to differ as it's in a restrictive area for air flow, there is an extra bend over standard. It all starts with as much air - that's cold, or dense before it get compressed. I'm convinced it'll be filling up with warm air, yes a heat shield of some sort will very much help, but it'll also reduce air flow imo
    But at the end of the day as long as you're all happy!!! If it works for you great!!
    Dec 2012
    243
    It works the results are proven! It's not in people's heads or placebo, there are numerous people who gain power, the standard one is far to restrictive above stage 1. The TIP alone is a big restriction. The bigger diameter pipe up to the MAF allow more air to flow and then when it reduces diameter the air picks up speed and is entering the turbo faster and there's more of it.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    Quote Originally Posted by S3_Jacko View Post
    here's the one i made. it's made out of an 2mm aluminum sheet. it includes oem air feed and i have tubes from the fog light to the filter. does the job. also now i added top edge seal, and seal arround the hole so it doesn't cut the itg hose.
    idea with the carbon fibre is to close complete right side over the filter including the part i've already made. it should seal the filter more and add a bit bling to the engine bay.
    Jan 2012
    473
    I don't necessarily agree with that theory - the turbo pulls air in, not the other way around, so you want a larger diameter pipe all the way to the turbo and not just to the MAF. I fitted the new Samco inlet pipe and it made 11ps on the dyno, no other changes, so there is a restriction there for sure.
    Jul 2013
    311
    It's the same argument about intercooler pipes if its smaller you get a faster air flow larger slower but the same amount of air is moved , the bigest problem is turbulent air ! Which is why the revo race intake is probably the best system
  28. #27
    Jan 2012
    473
    My comments apply for intercoolers too - ideally you want slower air to allow the IC's to do their job correctly i.e. provide the biggest drop in temp as possible - the faster the air goes through the less cooling happens. However, you can go too big and induce lag if you're not careful with the design.
  29. #28
    Dec 2012
    243
    Quote Originally Posted by nluk100 View Post
    Ideally you would have the bigger pipe all the way to the turbo but the reason for the smaller pipe is so the MAF still reads nearly correct. It will never read the same as stock due to the shape of the original MAF holder.
  30. #29
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    All I can say it that driving the vehicle now seems a lot smoother through the revs, an obvious difference at low end torque and not as jumpy with engine breaking when releasing the go pedal... There is plenty airflow in this area from stock... All be it, granted a shield as above will be more efficient and thats next on the hit list, you have that and the added airflow coming up through the meshed fog vents... The fact being its the beginning of winter and theres plenty of cold air around Glasgow at the moment... By speaking to the owner, these have been tested and dyno'd and the results for a Leon were an additional 16ps thats been the bes return hes seen... I'll be getting my car dyno'd soon so hopefully the results will speak for themselves... Car seems smoother, with a nice bitta noise coming from the engine bay now... Heat shield between filter and engine and extra airflow from standard duct and fog mesh, then I cant see why this could be anything else other than effective...
    S. likes this.
  1. Full custon TDI cold air intake fitted pics inside will upload video also
    By TDI140 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th October 2013, 18:35
  2. dv cold air intake
    By imported_fingermouse in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2005, 17:11
  3. *GB* ECS Tuning XAS Cold Air Intake System
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2005, 18:53
  4. cold air intake question
    By NxJxHxCedge in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th June 2004, 22:51
  5. Survey on Cold Air Intakes for A4 1.8T's
    By imajn34 in forum Tuning
    Last Post: 26th December 2003, 13:08
