AH FabricationsVolks Autos
Results 1 to 10 of 10
    Aug 2012
    75
    Blown Wiper motor? * I DO NOT HAVE HIDS*
    Hey guys,
    2 days ago my wipers all of a sudden stopped working. Its a well known fact that aftermarket HIDS blow the wiper motor and I cant seem to google anything about my problem because all the topics that come up are for HIDS
    Anyways is there any reason why my wiper blades would stop working if I have halogen bulbs?
    *Also the obvious statement would be to bring it to the dealer, but since I'm on air suspension and stuff most likely a dealer will try and blame "electrical" problems on that...*
    27,094
    Could just be the wiper motor has died, check all fuses & make sure no systems have been interfered with by your mods.
    Aug 2012
    75
    wiper motors just die with 21,000 miles on a car? I changed/replaced the fuse... And yea I haven't touched the wipers when I did my air install.
    27,094
    Mileage has nothing to do with it overall, could be worn, age, wiring, faulty manufacture, take your pick, however its not to say its the part at fault here, you need to research it more with a view to swapping the part out for another to test.
    So the fuse had blown?
    Aug 2012
    75
    No the fuse was fine. I just replaced it to see if that was the problem.
    Aug 2012
    75
    these are the bulbs im using....
    Aug 2012
    75
    So magically......... out of nowhere my wipers started working again last night
    Jan 2012
    SW London
    794
    Quote Originally Posted by burbank2broward View Post
    A few things i'd suggest to check then.
    I'm not too sure where the wiper motor is situated but make sure theres no standing water in or around the area. I've seen a fair few audis mostly older ones where they have standing water in that sort of area after the guttering system has become blocked up with crap.
    Is ur bonnet closed properly? The wipers wont work if the bonnets open or even if the sensor or something is dodgy that could be causing an issue.
    Do u have automatic wipers? Could be a problem with the sensor, although im sure u would have tried manually activating the wipers.
    I'd also try the following, without starting the car, key in, ignition on, key out, tap wiper stalk down. See if the wipers go into service mode. Could help rule out a motor fault. Also do ur wipers pop up/down ever so slightly when u start and stop the car?
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Aug 2012
    75
    It was about to pour after work so as a safety measure I went to check if my wipers worked or not before I drove home.... Andddd they didn't work.... So after further inspection.... The slot where the fuse sits in makes the fuse wiggly and loose, it's not making a tight connection.. Any way to make it fit well or do I need to buy a whole new fuse box?
    27,094
    You can get a ice pick headed tool or tiny screwdriver & push the fuse points back into the middle, to get a better/tighter connection again.
  1. What happened to the 'Sticky' about non-OEM HID's blowing wiper motors ?
    By mike foster in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd August 2013, 22:19
  2. Rear Wiper motor replaced-jet not working properly
    By jnielow in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2012, 13:15
  3. Replies: 58
    Last Post: 27th July 2012, 00:16
  4. Hid, Wiper motor problem?
    By grantDUBshaw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2012, 23:26
  5. MTEC hids killed my wiper motor
    By pawilliams100 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th February 2009, 08:23
