Chris NottAH Fabrications
    Jun 2013
    19
    BKD 2.0 Tdi - Lumpy at idle and slight stutter under load... EGR valve?
    I'm hoping it's a case of a dirty EGR valve, so 1st port of call is to remove and clean it. Do I use brake cleaner to clean the deposit/residue away, or something else?
    If it's not the EGR valve, can anyone suggest other suspect areas?
    Thanks.
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,209
    Follow Brodster On Twitter Add Brodster on Facebook
    Could be dodgy injector, fuel flow valve......not a lot to go on really so I think it will be a case of trial and error as it could be a multitude of things. Those are the usual suspects on the diesels
    1. EGR
    2. Injectors either dirty or not set up properly (normally coincides with excess smoke when cold)
    3. Fuel Flow valve.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/VCDS/Wagner
    26,720
    EGR, IMF, Fuel filter (which is common to be forgotten to be changed)
    Injectors can have a diesel purge as last option, simple enough process.
    Jun 2013
    19
    Thanks for that... I'll try working through a few of your suggestions and see how it goes.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    682
    Sounds very much like the symptoms of a blocked fuel filter. Our if curiosity Brodster, when you say fuel valve do you mean the one built into the lid of the fuel filter housing?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    Sep 2011
    36
    I'm just in process of ordering gaskets from a skoda dealer for inlet manifold, egr valve, egr pipe & anti shudder valve. Not disassembled mine yet but from looking on the net most modern audis suffer from the whole of this section carbon sooting up.
    Mines the 170 bmn so has swirler flaps in the manifold as well and im told these gum up. To be honest i'd clean as much of this section of parts as you can and see where you go from there. Looking at the pictures of some & it's the equivalent of furring of the arteries in humans. The pipe restricts & the amount of air being admitted to the engine is reduced.
  1. A4 1.9 TDI pd 130 misfire - cough/mis/splutter under load - judder on idle
    By ian-r in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2012, 20:09
  2. Strangle idle and drive 2.0tdi 140 BKD
    By tdisportuk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2010, 17:41
  3. high tick over and slight stutter
    By Mindrunner in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 21st January 2009, 02:46
  4. Rough idle and slight backfire!!
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st April 2008, 15:22
  5. FSi-Lumpy idling and starting problems
    By Aldo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2006, 16:00
