Just wondering at what stage you would need to consider upgrading the engine mount etc?
Polytek Poly PT Flex 60 Fast Cure - Shore A60 Polyurethane Rubber - 1kg Kit | eBay is a good idea, uses your own mounts comes in varies weights depends on your needs.
I noticed at Stg2+ that there was a bit of a clonking sound changing gear when accelerating hard,and that's a good indicator of the mounts being either worn,or not being up to the job.
Mine were changed for a set of VWR(Vibratechnics) fast road mounts.
Those are pretty hard,but not as nasty as solid mounts,which I'd say are pretty harsh for road use.
The THS mounts are a good choice also.
whats the cabin noise like with VWR?
My plan is stage 2 at the moment and was looking around and happened to come across revos mount kit, don't hear much people talking about replacing them tho? How many of the engine mounts maybe need replacing ? I might go stage 3 if I have the money so maybe something I should consider
When I say stage 3 I mean shark but I doubt ill manage it next year something ill prob do tho is it a hard job? Time consuming ?
THS FR3 Complete Engine Mounting System - Golf Mk5/Mk6 Type Chassis - S3 (8P) - Audi - Shop By Car will this mount kit also be good ? Read few reviews on it and these ones seem to be good? Revo ones will end up costing more and if these can do the same job then means I can put more money towards something els like cooler or that?
