Badger5JMB Retrofits
Results 1 to 13 of 13
    MAD_Adamski's Avatar
    Jan 2009
    314
    Let's talk Tdi tuning/clutches....
    Ok well having had a 1.9 tdi and tuned that I went with a Southbend stg2 clutch,,
    So I now have a sportback 170 that's been tuned around 220hp mark I think. I'm suffering clutch slip in forth gear +...
    So have people got any experience or advice as the 6 speed clutches are near 1k and that's well alot lol! My mapper said a brand new luk or sachs will be fine at that power and alot cheaper but I don't want to buy it then it slip.....
    Advice? Anyone done this?
    Thanks Ad
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    I have just supplied x3 Sachs/Loba clutches last week to customers so if you want a quote then PM me. They are not as expensive as you think.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    flying oyster's Avatar
    flying oyster
    Jul 2009
    wimbledon
    547
    helix or sachs loba kit wouldnt get a southbend again or smf myself
    S3 8L ming blue westys old car shed loads of mods
    Jan 2009
    314
    Can you both explain further? My Southbend was fine on my old audi?
    What's the Sachs rated too brodster?
    flying oyster
    Jul 2009
    wimbledon
    547
    Quote Originally Posted by MAD_Adamski View Post
    the clutch friction plate was dragging on the pressure plate /flywheel they had a problem with a batch and if you do a internet search your find them . the guys at darkside were brilliant and managed to get a replacment out of them for me but i still had labour costs and it left me with a bad taste in my mouth as far as southbend are concerned
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,402
    The Loba/Sachs Stage 2 clutch for the TDI is rated to 550Nm but will comfortably handle 600Nm. I have sent the Loba dude a meesage as I want to verify that they have them at this time and then I shall PM you a price. This is what you will get.
    The LOBA-Sachs sports clutch kit includes
    • Sachs Performance clutch cover
    • Sachs Performance clutch disc organic
    • LOBA Billet lightened & balanced single-mass flywheel made of special chromoly steel (6.7 kg)
    • Clutch cover bolts
    • Torque rating 550 nm / 405 lbft
    If you do go for one remember and buy a new set of flywheel bolts as the old ones will be useless as they are stretch bolts as Loba DO NOT supply them in this kit.
    Aug 2012
    68
    I'm thinking of getting a new uprated clutch for my a3 tdi quattro, i thought smf sounded like a tractor on a diesel and vibrated loads?
    Jan 2009
    314
    Maybe a paddle does I had a organic disc and it was better than the dual mass...
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,402
    Quote Originally Posted by swift View Post
    As taken from the Loba website to make you aware of the noise a SMF makes:-
    "please take note, when converting from the original dual mass flywheel to a single mass performance alternative, some vibration often termed as "chatter" can be felt at low RPM and also at idle in neutral - this is nothing to be concerned over"
    tdi-man's Avatar
    Jul 2009
    1,612
    Happy with my standard sachs flywheel with a Helix clutch can handle my 233bhp 309 ftlb remap.....
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Aug 2012
    68
    Quote Originally Posted by Brodster View Post
    Okay well if the "chatter" isn't that noticeably louder I will go with the smf or will the sachs dual mass, organic disc and sachs uprated clutch cover be able to handle 600Nm because I want to be running around 300bhp in the near future?
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,402
    PM sent
    Aug 2003
    292
    is there a limit to torque tuning with a DSG box? I've a 2007 2.0tdi SB 170 DSG, 50k miles FASH
    Was looking a tdi tuning plug in, seems good value
    cheers
  1. Lets talk about Shifiting/Clutching/RPM's
    By Sen Sen in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2008, 16:44
  2. A4 1.9 tdi - flywheel clutch replacement ?
    By joncat in forum Diesel forum
    Last Post: 24th May 2004, 21:06
  3. 1.9 TDI Serious Clutch Pedal Vibration
    By matt_splatt in forum General Technical / How To
    Last Post: 13th April 2004, 22:53
  4. 2.0 TDi Tuning ideas??
    By Ash1980 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2004, 16:18
  5. Whos the daddy of TDI tuning ?
    By Chins in forum Tuning
    Last Post: 13th October 2003, 12:01
