Badger5AH Fabrications
Results 1 to 8 of 8
    Mar 2012
    278
    Diesel Filter Fuel Hose Leak
    Hi guys
    I've developed a small leak from one of the two hoses that take fuel from the diesel filter to the engine. A main dealer Audi mechanic took a look and says I need to replace the pipe and that it's a simple job to do myself..... but unfortunately Audi want £66 for the pipe alone and TPS want £62. That seems an awful lot to me!? Apparently the pipes are only sold as a pair, so I have to buy both
    It appears the leak is coming from the general area of the arrow, running down the pipe and then pooling on top of the diesel filter. It's not a massive amount but I want to get it fixed before it gets worse
    I'm wondering if it's something I can get custom made to measure by a hose maker and how much I should expect to pay? or maybe I'm better off buying from a scrap dealer!?
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,117
    I might be wrong. Can you not just shorten it, cut 2cm off it and use a new hose clip?
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagust.co.uk
    E-Mail:info@philseagust.co.uk
    Mar 2012
    278
    Hadn't considered than Phil, thanks. I must admit I haven't even taken it off yet.... Hopefully removing it and refitting may be enough if it's worked it's way loose or something but nothing is ever that simple with this car
    Jun 2011
    138
    fuel hoses are different to normal hoses. They have a special coating to stop the fuel eating away at them. Should be able to get a universal fuel hose with same internal ID cheaper
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    27,129
    I've got a spare set of those pipes if you want to make me an offer.
    Mar 2012
    278
    Hi. I wouldn't know where to start with an offer.... Let me know what you want and I'll have a think about it. Do they come with the clips?
    27,129
    Yeah I think they have clips on, but just reuse yours, they retain there tightness.
    foursprungdugtechnique's Avatar
    Jan 2011
    Perth, Scotland PH1 2BN
    279
    Try a firm like Pirtek, they have all types of hoses, connectors and clips.
    I had a power steering leak caused by the near side intercooler cowling rubbing through the aluminium cooler pipe. Audi wanted £78, length of 10mm internal diameter hose and clips... £2 it was only a 2" piece I needed
  1. fuel filter clip/hose
    By knoxie in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2012, 23:54
  2. Braided Fuel Hose......
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2011, 20:33
  3. VW Passat wont start after diesel filter
    By A3-frankie in forum Diesel forum
    Last Post: 4th May 2008, 22:46
  4. Split Fuel Hose
    By Stringster in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st December 2007, 01:21
  5. Charcoal Filter Solenoid Hose connection
    By waveform2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th November 2007, 21:38
