EM TuningAH Fabrications
Results 1 to 8 of 8
    Oct 2012
    59
    audi a3 2009 change brake pads help
    hi guys.
    im gonna change my brake pads and need to ensure i have the correct tools, i know i need a piston tool but not sure if this will work for both front and back and also if this is correct tool
    Sealey VS024 brake piston wind back tool ***NEW ***SALE PRICE*** NEW*** | eBay
    or do i need the above and also
    Disc brake piston spreader seperator tool / brake calliper / pad BERGEN AT187 | eBay
    i used to just used a crow bar for my old car front but this time i think i shouldn't due to being a much better car.
    any help much appciated.
    ps. this is guide i saw How To: Change Brake Pads
    thanks
    d
    27,126
    1st tool is what I use, also make sure you spray some lube, say wd40 around the rubber boot of the piston, so it doesnt twist & tear as you wind piston back.
    Oct 2012
    59
    hi mate,
    does this tool work for the front as well?
    d
    Mar 2013
    Milton Keynes
    34
    Quote Originally Posted by deek19790 View Post
    hi mate,
    d
    The Sealey tool is normally for rear calipers where the piston indexes as the pad wears to keep the handbrake in contention. The second one is a generic tool for returning pistons in a single or double piston regular caliper that has no handbrake scheme as those on the front.
    Dave
    Oct 2012
    59
    Hi mate,
    Cheers for that.....
    D
    XFi
    Jun 2010
    344
    If the bolts are the same as on my 2009 S3 then you will need a Spline tool bit but someone else may be able to confirm as I think it's either M12 or M14.
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    I've got this kit, does the job every time. I use it quite a lot.
    BRAKE CALIPER PISTON REWIND WIND BACK TOOL KIT 22 PIECES, car service tool | eBay
    Will do your fronts & rears with ease.
    I wouldn't buy either of the kits you have posted.
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    For many years, I've been using a G Clamp for front piston and grinder's Peg spanner for the rears. Works okay.
  1. Genuine Audi Electric handbrake caliper A4 S4 drivers 2009> with brake pads free
    By nicolaaudi1978 in forum For Sale/Wanted - Audi Parts
    Last Post: 3rd April 2013, 23:57
  2. Replies: 0
    Last Post: 3rd April 2013, 23:52
  3. help changing brake pads quite urgent!!!
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th June 2008, 17:57
  4. Brake Pad Help
    By chuckys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2006, 21:35
  5. Changing brake pads
    By Lynas in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th February 2006, 10:44
