EM TuningVolks Autos
    Nov 2013
    Exclamation A3 2.0 FSI Camshaft Sensor Issues
    Let me start my story with, I have bought an Audi A3 2.0 FSI (2004) with 72000 on the clock. It came with a full service history which did confirm that the timing belt has been changed. I never inspected if it really was or wasn't. One day I was gonig home and the car has just stopped. My friend checked it for me and the timing belt has snapped! I could not belive it. But I thought it was my fault I should of double checked it. My friend has rebuilt the engine for me we have changed everithing that needed to be changed. The car started fine and everything. The second day the car did not want to start when the engine was warm it would only start 3rd time. We conneted it vac and did say it was the camshaft sensor. Then we did change the sensor but its still the same it starts first time when the engine cold, but it wont start first time when the engine is hot most of the time. It would always start 2-3 time I am not too sure what it could be. I have also noticed a very poor mpg. It use to be 30 plus but since I had the engine replaced its like 20 but max 24! I had done about 1500 miles since I had the engine replaced but it is getting really fustrating now. Any help or advice would be great!!
    27,099
    Welcome to the site.
    Check your maf & maybe coolant sensors, if they report back incorrect readings, then of course it may use more fuel & cause starting issues.
    Nov 2013
    Thank you for the fast reply I will go and change both and will let you know if it solved the issue.
    27,099
    No guarantees, but its certainly 2 to check.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    given it's after the head repair, it's more likely to be incorrect crank to cam timing
  1. HELP need urgently camshaft sensor
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2009, 19:38
  2. A4 2.0 FSI Cam Sensor Fault
    By RLilleyman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th September 2009, 17:51
  3. Camshaft Sensor Help!!!
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2007, 18:55
  4. camshaft sensor and abs sensor
    By Emmo in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2007, 21:29
  5. Parking sensor issues
    By dan1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th April 2006, 09:32
