Chris NottBadger5
Results 1 to 7 of 7
    210_MIH's Avatar
    Drive it like u stole it
    May 2012
    103
    Flat battery and RNSE question
    Hi all
    My battery in my A3 is completely dead. Cars been parked up for a few weeks. Didnt start with jump leads so thinking of removing battery and charging inside.
    Just wondering if il need a code for the audi sat nav unit?
    210_MIH's Avatar
    May 2012
    103
    Ps. Anyone know how to remove the battery? Im clueless
    Mar 2011
    Cleveland
    996
    If original RNS-E, the car will remember the code.
    Take the top cover off the battery and undo the terminals. Look down the left side of the battery and you will see a 13mm bolt holding a clamp on the bottom of the battery. You'll need a ratchet and long extension to reach it. Remove bolt and clamp and lift out the battery.
    Apr 2013
    bham
    55
    you battery may need abit of mineral water to top it up, or if you been driving it with no water its probably damaged beyond repair now jus check if the water level is low on it if it is just top it up with abit of mineral water and try it then, the sat nav code should be inside your service booklet
    210_MIH's Avatar
    May 2012
    103
    Cheers guys. Will do that tomorrow. Parked up for four weeks eventhough i started it every other day. Hope i dont need a new battery
    Mar 2011
    Cleveland
    996
    Starting it every other day is probably what flattened it. It would need a run of 10 minutes or more to put back in what you took out!
    And you can't top up most modern batteries,,,,
    210_MIH's Avatar
    May 2012
    103
    Ohhhh lol. Thanks for that - will have to be real careful in future
  1. Help wanted! Flat battery, got it started and it wont run right!
    By jackpilk in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2012, 12:34
  2. A6 C6 Avant '07 2.0 TDI - hazard lights switch on and flat battery
    By greg1983 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th January 2011, 15:03
  3. Key fob battery and c/l question
    By olds_cool in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th March 2010, 21:33
  4. Retro-fitted rns-e and now have flat battery!!
    By foolish3uk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th February 2009, 21:28
  5. Flat battery and electrical drain....HELP!
    By CJA318T in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2007, 09:08
