AH FabricationsVolks Autos
Results 1 to 27 of 27
Like Tree1Likes
  • 1 Post By danb986
Thread: Horrible Morning! - No lights on dash
    Jul 2013
    Manchester
    109
    Hi there,
    I have an Audi A3 sportback 1.9tdi 2009 (facelift model)
    This morning i woke up, not only was it a very cold morning but when I got in my car to come to work. My car decided to not start.
    This is the problem/s
    -When i turn the ignition on, no lights on my dash light up
    -All other electrics in the car still work (heaters, lights, stereo, alarm, windows)
    -Car will start but cuts out after a second or two (immobiliser I guess?)
    I have checked all the fuses and all seem fine.
    I have tried disconnecting the battery for 30 seconds and connecting it again (seen online this had worked for similar problems)
    Now im stumped when i parked it up Friday it was fine.
    I dont know if its coincidence or not but this morning is the first time this year my car has been frozen over.
    Any suggestions would be great as im short on cash at the minute and have no other options but try and figure it out myself.
    Thanks for any replies.
    Chris
    26,776
    Does the coil icon flash constantly with ignition turned on?
    Jul 2013
    Manchester
    109
    Hi NHN,
    Thank you for your reply
    Not one light on the dash comes on
    26,776
    That sounds like the cluster is buggered, check all fuses on end of dash drivers side behind hidden panel & as under the hood in front of passenger, under a closed plastic housing with sliding locks each side to undo.
    Jul 2013
    Manchester
    109
    I have already checked the ones on the drivers side, will check the ones under the hood when I get home (by bus!!!).
    If all fuses are fine i'm guessing by your last reply its the instrument cluster, how would I know if this is what it is for certain?
    26,776
    Plugging another cluster in, trying to login to cluster with vcds.
    Jul 2013
    Manchester
    109
    Ahh right, not something I could do then..is this going to be a costly job?
    26,776
    Whereabouts are you located?
    Jul 2013
    Manchester
    109
    Manchester, M40
    26,776
    Give N8 a shout as he's Salford area.
    Jul 2013
    Manchester
    109
    I have sent him a PM. Hopefully he will get back to me soon, cant cope with buses!! haha
    Jul 2013
    Manchester
    109
    Well i got home last night and it started... the fact that yesterday morning was the first morning my car had been frozen over this year leads me to think it was the frost... bizarre!
    Nov 2013
    Quote Originally Posted by wrightyrx7 View Post
    I have this exact problem at the moment, i haven't been so lucky with it just starting tho, anyone any ideas? all fuses seem to be fine!
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Sorry to resurrect a week old thread, but I might have some info that could help someone else doing a search.
    My brother's work had a 2007 A3 Sportback come into his bodyshop the other day. All was fine for a couple of days of moving it around, then they went to move it again and the dash was dead and they had the same starting problem mentioned above.
    They phoned Audi as they'd only worked on the rear end where it was hit and couldn't think what would've caused it.
    Audi told them it was due to static build up and suggested they disconnect the battery overnight and it would be fine when you reconnect it in the morning. It worked and next morning everything was working as normal.
    I'm not sure why or how static build up occurs (or even if this is correct), but it did the job and Audi seemed to know the answer straight away as if it's a common(ish) issue.
    Worth a go if you're having a similar problem.
    wrightyrx7 likes this.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    Sportback owner
    Apr 2007
    France
    466
    In the world of electronics, static build-up generally results from poor grounding. Also, frosty air is very dry, and that indeed can cause static. As soon as it turns wet, the static leaks away. In danb986 case, there may have been some interference with the grounding wires at the rear of the car, or some added component/loom not adequately earthed. Have never heard of static build-up in cars, but it seems it may well be possible. Just a thought.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Jul 2013
    Manchester
    109
    Well if your in the Manchester area you will see that since i started the post. This morning is the second time my car has frozen over...and the second time it wont start.
    Im gonna try the whole disconnect the battery tonight.
    BUT: as a coincidence.. only a few week ago the back bumper on my car was replaced.
    Jul 2013
    Manchester
    109
    Well someone the following:
    "Sounds like the terminal 30 relay is sticking when cold and not activating the main components. Weird circumstances though as relays are not usually affect be weather conditions unless it's suffered with water ingress."
    anyone know where i can locate this?
    Sportback owner
    Apr 2007
    France
    466
    Don't know what a "terminal 30 relay" is, but this link may help: http://tos.pp.fi/koukku/sulakkeetjareleet.pdf Good luck.
    Jul 2013
    Manchester
    109
    Hi Geraldy,
    Thanks for your reply.
    You reply above re "Static Build up" could be the problem with mine to.
    I had work done on the back end of my car, when I went to check on it they had all the rear lights out of the car. This problem has only started on frosty mornings since i had this work done. Could it be the grounding when they put the electrics back in?
    I don't see how this could cause a problem with the dash not coming on, but then again I'm no good with electrics.
    You seem to know what your talking about, could you kindly supply me with an explanation - for me to explain to them - when i take it back to them and tell them i want them to check the grounds in the rear.
    Sportback owner
    Apr 2007
    France
    466
    Seems odd that two cars have reported something similar, and in both cases the rear bumper or rear lights have recently been worked on. I would be quite surprised if the fault is occurring due to static, but maybe there is a connection (no pun intended). There are indeed two official grounding points at the rear. They are somewhere on the 'C' pillars, one each side. Perhaps when working on the rear they have somehow disturbed the grounding system...hard to know. However, I see no reason not to ask them to check carefully, both visually and by ohmmeter that what is supposed to be grounded is in fact grounded properly. This fault could be as you have mentioned, some electrical component failing when very cold. If so it must have happened before to some unfortunate customer(s), so Audi should know about it. Do make sure that the battery connections are on real tight, and that the battery grounding strap is not corroded where it attaches to the car. Freezing conditions also cause metal parts to shrink a bit, and if these are electrical connections it may give some problems only when cold. That's a long-shot but worth a look-see.
    Jul 2013
    Manchester
    109
    Many thanks for your reply Geraldy212
    I am going to the garage that did my bumper later on. So hopefully they will have a look.
    But on the phone he didnt seem to think it was them that caused it. So might have to locate them myself :/
    DOnt suppose you know of any diagrams that show how you get to the grounding points?
    Sportback owner
    Apr 2007
    France
    466
    No the Haynes manual just indicates that there are two grounding points at the rear, located on the left & right 'C' pillar. Have never seen these points, and I expect you have to take the rear panels off to see them. There is no reason the garage cannot go in and examine what work they did and check the looms/connectors. As far as I know, only the reverse-assist option has components connected to the rear bumper. But there are lots of wires in the rear, feeding rear/stop/fog lights wiper and stereo amplifier etc. Good to have a look. If this does not show any problems, suspect a component is getting cold-soaked and failing. If you can get a member to make a VCDS check when cold and not starting it might show up something. Also, the ignition switch could be the culprit as they are known to fail on the A3.
    Jul 2013
    Manchester
    109
    Well I had its scanned, but no errors appeared...which isnt a surprise considering its running find now its not frosty.
    Found out today my managers husband has a Ross-Tech Cable. So gonna get it off him and keep hold of it until it does this again on the next frosty morning we have and scan it.
    Thing is will it scan if the instrument cluster/dash isnt coming on when i have this problem?
    Jul 2013
    Manchester
    109
    I have made a video, incase it helps shed light on my problem.
    Sportback owner
    Apr 2007
    France
    466
    The fact that it starts should mean that the ECU is operating under 12v power, as are other circuits such as climate control. The thing that does not seem to be working is the instrument cluster (which I also believe controls the immobiliser). In other words, at very cold temperatures, the instrument cluster controller, or the printed circuit board or the connectors may be failing. Possibly an open-circuit due to low temperature. To test out this theory when it happens, you could quickly pull out the cluster, take it inside the house until it warms up, then try it again.
    Jul 2013
    Manchester
    109
    Hello again Geraldy212,
    This seems like a good theory. Next time it does it this is what i will do. Once the cluster is out do you know if the circuit board is visible? If so maybe i will see the open-circuit while its cold.
  28. #27
    Sportback owner
    Apr 2007
    France
    466
    No I do not know if the printed circuit board will be visible. It may be very hard to see any open circuit, but worth a good look. Taking out the cluster will also exercise the plug/socket and hopefully clean off the contacts a bit. Other than that, I am fresh out of ideas. Good luck.
  1. Problem with esp light on dash...
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2011, 15:34
  2. Warning Light on Dash
    By steveh in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2006, 17:27
  3. Warning Lights on Dash
    By GarryX in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th December 2005, 09:14
  4. ESP Light on Dash............
    Last Post: 21st December 2005, 16:40
  5. Engine management light on dash
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2005, 17:55
