Results 1 to 17 of 17
    Apr 2013
    bham
    55
    where can i get this hydraulic brake pipe pics inside
    i need some urgent help please ive only broke a brake pipe on my a3 2.0 tdi, when i was changing over my calipers and hoses on my passenger side (ns),
    i was undoing a nut that had a pipe coming from it (pics below)that fed into the arch, on further inspection ive found out that it goes to the abs block (hydraulic block) which is situated just behind and under the battery, you can undo the pipe by a nut on the block and replace it but god knows what part number it is and even what is called, or where i can even get it from. please can anybody assist me
    ive switched the engine on and on my cluster its telling me theres a brake leak etc warning warning, and this means i carnt drive my car until i get it fixed now which has messed everythink up, if anybody knows what its called or what part number it is or where i can buy it from it will be very much appreciated,
    Apr 2013
    bham
    55
    and by the way i attached a bit white plastic bag to the pipe which you can see in pics to use as a guide, thats the one that needs a replacement
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,091
    I think you have only 2 options.
    1. Get the pipe from a scrap car
    2. Go to the dealers and explain/ point out the part you need
    Sorry
    Phil
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagust.co.uk
    E-Mail:info@philseagust.co.uk
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    896
    Growing old is mandatory, growing up is optional
    Jul 2013
    311
    or all you need to do is get a length of new pipe and a flaring tool and repair what is their
    Aug 2006
    NI
    785
    bring the old pipe to a motorfactors that can make you a copy of the old one. doesnt have to be exact as copper is pretty handy to bend etc. phone first though and make sure they do it.
    back to boost, oh how I missed thee....
    Apr 2013
    bham
    55
    omg im just abit mortified right now about it reality has sunk in and no car!!!, if i carnt buy a brand new one im going to have to get it repaired, if i undo the broken brake pipe hose(line) what type of shop could fix it? and what sort of price are we talking
    Aug 2006
    NI
    785
    sub tenner Id imagine. halfords sell the parts if you can catch them before they close (well my local halfords has them anyway). But they cant make them up. you need someone with a flaring tool to flare the ends.
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,091
    How are you getting on with this?
    Any news
    Apr 2013
    bham
    55
    hiya all good news is i have just literally got in, just got the replacement part off another audi a3 2.0 tdi breaking for £10 which is good news, it was like trying to find hens teeth,i will have it fitted in the morning sometime thank god for that,it took alot of phoning around visiting audi breakers etc but in the end i was making sure i was getting one today,
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,091
    Good news then ;-)
    Glad you got it sorted
    Phil
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    Now you'll need to change the brake fluid and bleed the whole system to make sure you have no air in the rest of the system as you started it up with a major leak the abs pump could well be empty or full of air
    You may well need someone with VCDS to activate the abs pump but at the least it'll need a pressure or suction bleed kit, they are not as easy as older generation braking systems (2 person method)
    Good luck!
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Aug 2006
    NI
    785
    will the abs pump not only empty if it was activated while dry? master cylinder may need bled unless the OP jammed the brake pedal on prior to the work.
    fun times ahead
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    Gravity.
    The air will rise into the pump as the fluid leaks out, that will 99.9% need the abs pump bleeding.
    Apr 2013
    bham
    55
    omg guys i thought it was going to be a quick fix theres always something else, ive fitted the metal brake pipe all went good ive jumped into the car turned the ignition on brake warning still on there ive pressed the brake peddle multiple times still not working,if i keep tapping the brake pedal quickly it will build up and be stiff but a second later it just goes floppy and goes all the way in, so ive got no brakes so no car still how do i bleed these brakes please people, and is it normal dot 4 brake fluid? i need to buy, i just need to get the car back on the road asap if anybody could give me some tips that would be much appreciatedd
    Apr 2013
    bham
    55
    hellppppppp pleaseeeee
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    Seriously no offence but leave well alone if if all you've done is replaced the pipe and think it'll all work fine
    They need bleeding by someone who knows what they are doing... Get a mobile mechanic out
    Brakes are far too important, you'll end up killing someone if they are not done correctly
    I applaud you for giving it a go, but if your unsure, and I only assume this as your asking for help, please get a mechanic
  1. Where can I get this spoiler....
    By mikehturbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd March 2011, 19:37
  2. Where can I get this steering wheel?
    By S3 MRU in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th November 2010, 20:00
  3. Help where can i get this today 06A-133-783-AS mani pipe
    By hoban81 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2010, 19:32
  4. A3 - Bluetooth Retrofit - Where Can I get this from
    By Marcyboy in forum In-Car Entertainment
    Last Post: 11th December 2007, 09:46
  5. Where can i get this pipe from?!
    By DPM in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2006, 16:33
