JMB RetrofitsBadger5
    Jun 2009
    12
    OEM Sport suspension is too firm!
    Roads in Manila are pretty bad, and I wonder if an Eibach Pro Kit and Koni FSD shocks would sit at the same height, but ride much better? Alternatively, are there other comfortable options? Don't want to go with coilovers.
    2009 A3 Sportback 1.8 TFSI
    Oct 2013
    Australia
    47
    I find H&R (50mm but 25 should be similar) much more comfortable than OEM s-line suspension.
    2012 Audi A3 8PA Sportback IBIS WHITE
    Panoramic Sunroof|S-line Interior+Exterior|18" OEM Rotor Alloys Gloss Black with CNC machined polished edges|Black Badges & no. plates|55% Black Window Tint all around|50mm H&R|APR Stage 2|APR DP|APR Catback|Carbonio Intake Stage 2|GFB DV+|HP DSG Remap|S3 Pedals & OSIR Footrest|H&R rear 20mm Spacers|S3 IC|6500K LED Interior and number plates|Nokya Arctic White bulbs DRL, fog, low/high beams|Aspec Charge/Discharge pipes|R8 coilpacks
    Jun 2009
    12
    Thanks for your response. My A3 has the Sport suspension, which is lower by something like 10mm. SportLine is even lower and stiffer. Do H&R springs tend to ride softer than Eibach Prokit?
    Sep 2013
    24
    Ideally you'll need bump and rebound adjustability for comfort... look into PC coil overs.
  1. A4 B6 OEM sport suspension COLOUR!!
    By audi130 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th June 2010, 23:44
  2. A4 B6 OEM sport suspension part numbers
    Last Post: 12th June 2010, 00:04
  3. SPORT SPEC SPORTBACK - IS THE RIDE TOO FIRM ?
    By shilts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th March 2010, 20:47
  4. Audi A3 Sport suspension too firm
    By Monsoon in forum Handling
    Last Post: 8th October 2005, 15:50
  5. Sport suspension on an a4 Ultra Sport..too harsh?
    By Zinny in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th December 2003, 05:01
