EM TuningChris Nott
    theo289's Avatar
    Oct 2012
    Bristol
    176
    Would you put two stroke in a diesel engine to clean the inside of the engine out?!
    Rather strange as a question but would you put two stroke in diesel fuel to clean out the engine? Reasons why i am asking this questions is that an old friend of mine who has a Ford Mondeo ST Diesel with around 100k miles on did exactly this and said that it improved the car, its MPG and cleaned out the engine! Supposedly this is something commonly done - is it wise? Will i just bugger up the engine?
    Feedback appreciated
    May 2012
    RETFORD, NOTTS
    1,753
    I always add 200 ml every 3-4 tanks if I've not used optimax. Has to be red mineral based low ash oil. Not synthetic stuff. Done no harm and hardly smokes at all when using it on my Pd engine
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    theo289's Avatar
    Oct 2012
    Bristol
    176
    Quote Originally Posted by @udi A3 View Post
    Okay great! what is the perks of doing it except for smoke?
    TDI140's Avatar
    May 2011
    1,347
    My mechanic use to put £2 of petrol in every like 3 months with a full tank of diesel in his a4 2.5tdi said it helps clean the system and fuel line and injectors ive never done it personally but might be good for the car, i usually use forte diesel treatment
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Jul 2013
    311
    i wouldn't bother to be honest no need to add oil to the fuel, it will increase the combustion temperature and may result in damage to the turbo, it is also not designed to run through the tiny holes in the pd injector of which can cause issues and the fact that vw/audi state not to run any additives just regular diesel
    Sep 2012
    LEEDS
    125
    I do it every 2-3 tankfulls .
    It came highly recommended and also increased the mileage .
    A6 2.5tdi quattro sport triptronic 550miles on a full tank. (long run and about 80 miles around town )
    happy with that
    Absolutley disgusting around town it is
    genuine parts =genuine service
    Treat it right it'll keep you on the road .
  1. Would you put this back on your car??
    By lil_coz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2012, 17:30
  2. What wheels would you put on my car??
    By CHRIS555 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th January 2011, 21:15
  3. What diesel would you recommend for 3k?
    By benw123 in forum General Automotive Chat
    Last Post: 26th January 2010, 22:54
  4. Would this put you off?
    By Mandala in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2007, 08:14
  5. If you had the option would you?
    By gtdog in forum Other Brands & Models
    Last Post: 4th April 2003, 09:30
