AH FabricationsChris Nott
Results 1 to 14 of 14
    _Zerocool_'s Avatar
    Jan 2013
    217
    Flashing ESP light
    This may be a dumb question but is there a way of turning the ESP off on an 8p S3 (10) without the damn light on the dash constantly flashing? Cheers
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    When is turned off the light should stay on, not to flash. It flashes only when the ESP is on and is making corrections.
    You can't turn off the ESP and the light.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,217
    Quote Originally Posted by Johnny Bravo View Post
    different on newer models
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    6+1 Gears
    Jun 2009
    Romania
    797
    Hmmm... How?
    _Zerocool_'s Avatar
    Jan 2013
    217
    Well when I hold down the ESP button it says 'ESP off' then the ESP light flashes constantly. Bit of a distraction...
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by _Zerocool_ View Post
    Should just be a steady orange light of a car skidding with 'off' underneath it. No flashing.
    Flashing usually only occurs when the system is active, whilst trying to maintain grip (ie driving like a loon)
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    _Zerocool_'s Avatar
    Jan 2013
    217
    Well the 'ESP OFF' light in the centre display is just on but the icon of the car skidding just below the 4 and 5 on the rev limiter display constantly flashes. Its a bit of a pain because I prefer the cars handling with it off. So does this not happen in other peoples S3s?
    If this is normal then fair enough. I don't think its a fault as everything seems ok with the handling, power delivery, 4x4 grip etc...
    Would it be an option in the VCDS? Maybe I could change the setting there?
    Any help would be greatly appreciated.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    If ESP off, the light should remain constantly on, not flash.
    Must be a glitch in it somewhere, get him scanned.
    _Zerocool_'s Avatar
    Jan 2013
    217
    Will do. until then I'll drive around with my eyes closed. I won't see the flashing light then!
    _Zerocool_'s Avatar
    Jan 2013
    217
    Ok finally got round to having the car scanned by VCDS.
    It did show a fault,
    1 fault found
    00448 - Haldex clutch pump (v181)
    0011 open circuit - Intermittent
    It only showed this occurring once two weeks ago when I got the car remapped.
    No other faults and the ESP still flashes when off.
    New clutch pump needed? I've not noticed any difference with the 4wd
    I'm going to go back in a week and see if the fault shows up again.
    sabers's Avatar
    Oct 2013
    nottingham
    114
    mine flashes swell but its a 1.8tfsi , works as normally but just flashes constantly when turned off.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,274
    You could on the 8L by changing the adaption code in VCDS so you probably can on the 8P it's just a case of someone finding out the code.
    The first thing I used to do when starting my S3 was turn off the ESP so this meant it was always of without needin to press any buttons or have the yellow light.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,849
    On the 8P3 ESP will automatically reactivate under certain conditions... sure I read it in the owners handbook.
    Hows the Tracking on that car, OP? Had any meetings with kerbs or potholes whilst you were driving in your preferred manner? Ever had it tracked?
    I once had a car throw an ESP hissy fit after someone side swiped me on the M1! Laser Tracking sorted it.
    Edit: From my 2009Owner's Manual, Page 151 (Intelligent Technology) Column 2, Paragraph 3:
    The ASR is also deactivated when the ESP is switched off, however the ESP is reactivated while the vehicle is under braking, and remains active until the vehicle has reached a stable driving condition.
    ...meaning, if you slam on the anchors, then immediately chuck it into a corner you can expect the ESP to have something to say on the matter.
    You'd probably do well to read both pages of the section (if you haven't already), it's very informative.
    2009 A3 SB 2.0T DSG S line
    _Zerocool_'s Avatar
    Jan 2013
    217
    Cheers for the posts. I've never hit a kerb or pothole but I might get the tracking looked at if that's a possibility.
    Makes sense that the car will keep an eye on things and turn it back on if things get a bit hairy.
    If anyone knows how to turn off the light using the VCDS that would be awesome! I'm hooking it up later on in the week to change the locks so that all the doors and boot open with one click anyway.
  1. Guide: ESP Light On- Glow-Plug/Engine Light Flashing - Cause & Fix Inside!
    By Yoof in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2014, 09:21
  2. ESP Light on and Glow Plug Light Flashing - Car Cuts Out! Help!
    By jay786 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th June 2012, 18:39
  3. No power when pulling away & ESP light flashing?
    By lil_coz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th December 2011, 16:34
  4. Indicators constantly flashing!/ Esp light/climate/key fob opening,etc.etc
    By sabs46 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st July 2011, 18:54
  5. ESP Light on solid /Glow Plug light flashing??
    By vincenzo_2k in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2008, 21:23
