AH FabricationsEM Tuning
    Helifella's Avatar
    Flying low level
    Nov 2011
    Knaresborough
    351
    Follow Helifella On Twitter
    Solar top-up for battery
    Hi all,
    Have any of you used a solar panel to keep your battery in good condition whilst it's not being driven?
    I have a 12W 17.5V panel suitable for 12v applications available which can connect either via the ciggy socket or directly onto the terminals. It also has a diode to prevent battery discharge during the night.
    The question I have is whether the car will allow the solar panel to push the power into the battery via the ciggy socket (always live, not ignition switched) being such a complex car?
    If I connect directly to the battery I would need to lift the bonnet, disconnect etc before each drive, whereas via the ciggy socket I can jump in and unplug it prior to starting up and go.
    By using a solar panel it should also keep my battery voltage above the cut-off threshold of my camera system thus allowing the camera to stay in parking mode for extended periods ie when I leave the car parked up while working away.
    Regards
    HeliFella
    I.A.M. Member http://www.iam.org.uk/about-us/
    '61 spec, A3 Sportback S-Line Black Edition in Ibis White, EM Tuning upgraded LED extended interior XL lightpack,
    Duxback Glass Treatment, Diamond Vision front fog lights, shortened number plates,
    gloss black rear rings & black edition S-line wing badges. Blackvue DR550GW 2 channel in-car camera with Smart Power battery protection.
    Jul 2011
    106
    I can't think of any reason why it wouldn't. The panel won't even come close to the fuse's max rating. You should be fine.
  1. Cover for Battery and Control Unit compartment for 2.0 TDi S-Line
    By coldkiwi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd February 2012, 07:15
  2. After Run Pump - Can You Set How Long it Runs For? (Battery Died)
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2011, 11:06
  3. Top Tip for Better Fuel Consumption!!!
    By Sulli in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th September 2011, 21:19
  4. Top Mount for S3.. Which ones?
    By coyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2011, 23:40
