AH FabricationsChris Nott
Results 1 to 9 of 9
    Nov 2013
    36
    Car not starting when warm? 2.0 FSI 2004
    Hello guys, i'm new to this forum and i hope someone can help me.
    My car isn 't starting when it is warm at 90 degrees. It is fine on a cold start, i've had the cam sensor replaced as it came up on VAG COM testing, but after that it still came up after being cleared, replaced it with another new sensor but is still coming up on diagnostic. The car also feels lump and unsteady when idling.. Not sure if this has anything to do with it.
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by Leeseager View Post
    Coolant temp sensor or maybe a bad starter motor dependant on year
    Nov 2013
    36
    Quote Originally Posted by Chillout View Post
    have you had this problem before? My car is 2004 model, think the starter motor is fine.
    anybody else that can help?
    Nov 2013
    36
    also how come this wouldn't show on a diagnostic?
    Nov 2013
    36
    Bump
    Apr 2013
    Aberdeenshire
    592
    Bump
    You probably would be better reading the coolant temp sensor when it won't start with vcds
    Oct 2013
    kingsbridge devon
    13
    Follow DA55TER On Twitter
    The same thing happened with my TT. I changed the coolant temp sensor, found a genuine part on eBay or £10, changed it myself, and been perfect ever since. I know its not the same car/motor etc. But worth a try.
    Nov 2013
    36
    Quote Originally Posted by DA55TER View Post
    You have exact same happen? Car is completely fine and drives perfectly cold but doesn't start at all when hot?
    Oct 2013
    kingsbridge devon
    13
    Yep. Drained the battery flat trying to start it when I went to Morrison's. Lol. Was embarrassing... walked home, called the AA, walked back the car a while later... the car was cold, and started first time. Read on a forum somewhere that the car under fuels when it thinks its cold, or something like that. Ordered the part. Took me 5 minutes to fit it. And its been fine ever since.
  1. Car not starting when warm? 2.0 FSI 2004
    By Leeseager in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st November 2013, 11:21
  2. 2.0 FSI not starting from warm. HELP!!!
    By mu11y in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th July 2007, 13:26
  3. 2003 A4 1.8T - Car Will Not Start When It is Cold
    By laura in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2004, 17:39
  4. Def. Problem, Car not starting when cold!
    By charTT in forum TT/TT-S/TT-RS Forum
    Last Post: 14th April 2004, 22:10
