AH FabricationsBadger5
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By andyam
Thread: Retrofitting coming home lights uptodate information
    Mar 2013
    West Yorksire
    26
    Alittle late yes but i tried the coming light mod by earthing pin 12 from block E . Set everything up on VCDs and no luck just a fault coming concerning the light sensor . Am i out dated and does my car this sensor in order too make the function work? My car is a 2004 A3 thanks all
    andyam's Avatar
    Jan 2011
    Bristol, United Kingdom, United Kingdom
    359
    Hmm weird I have this function installed, did the same no problem. I don't even have a light sensor. Have you done a search for the guide? There is a lad who put a guide up and was spot on with the instructions.
    mozza1202 likes this.
    Now: Audi A4 B8 2.0 TDi SE - Silver, Bluetooth, Parking Sensors, Auto Lights/Wipers, Auto Dimming Mirror, Hill Hold Assist.
    Before: Audi A3 8P2, 1.9TDi Special Edition, Silver,
    Armrest, MY09 Rear Lights, R32 MK5 Alloy Wheels 18" Gloss Black, Gloss Black Sline Grill, Windows Tinted, Carbon Wrapped Trim, Wind Deflectors, Alarm Beep, LED Interior and Number Plate Lights, Cupra R Splitter, S-Line Springs, footwell lights, S3 Pedals.
    andyam's Avatar
    Jan 2011
    359
    What I also found was, before screwing down the earthing wire, tap it on the earthed point, when it's activated it was light up your headlights. Tap it again and switch off the function. That should be a good test for you.
    Here is the link btw
    http://audiretrofit.quinlivan.net/cominghomelights
    JS3
    Oct 2011
    216
    Can you code this without installing the repair wire first?
    This should tell you if the code is accepted.
    2010 S3, Sprint Blue, S-Tronic, RNSE, Cruise Control, Interior Light Pack, Upgraded LED Interior Bulbs, Heated Seats, Hill Hold, Boot Buddy, Fog Turn Lights, Revo Stage 1, De-Wipered
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    No need to ground the wire. As Andy has said, tap the end of wire to activate and deactivate. When not in use, use some electrical tape to wrap around the exposed wire to ensure it does not accidentally swith it off.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,392
    I always just code the car first then put in the wire and tap on a grounding point to activate, once done I remove the wire
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    JS3
    Oct 2011
    216
    Ah so are you saying the wire only needs grounding once to turn it 'on'. And then you tap it on ground again to turn it off?
    So in theory, if I coded, tapped ground, I could then leave it turned on forever more?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,392
    yep!
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  1. coming home lights
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd September 2009, 07:12
  2. Adjusting time-delay on leaving/coming-home lights...
    By FactionOne in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th October 2008, 23:05
  3. Coming Home Lights
    By Ian_C in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th September 2008, 20:05
  4. Audi A4 B7 - Coming Home Lights
    By stevehall in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd September 2008, 15:00
  5. Coming home light function
    By Tolmie18 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd October 2007, 20:51
