Volks AutosChris Nott
    Sep 2011
    43
    A3 tdi 170 bmn egr / manifold gasket part numbers
    Hi just wondered if anyone knew the part numbers for the gaskets to remove the inlet manifold & egr valve on the 2.0 tdi pd 170 bmn engine. Seen pictures on here of some really crudded up & think for the the relative cost it's worth a shot at cleaning out the manifold & egr. If anyone has done this & had specific pictures of doing this for this engine, if they could post a few piccys I'd be very grateful.
    So I'm guessing :-
    Inlet Manifold gasket
    Inlet manifold to egr body gasket
    Egr inlet pipe to egr body gasket
    Egr to throttle body gasket
    Throttle body to lower pipe gasket
    Is that about it?
    Thanks in advance.
    MAD_Adamski's Avatar
    Jan 2009
    314
    TB and get have built in rubber gaskets the no need to replace I think you only need a inlet gasket!?
  1. Audi A4 Avant 2.0 TDI 170 - injectors, EGR and Intake Manifold Flap
    By agedog in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th March 2012, 20:46
  2. 140 or 170 clutch - which is best? - part numbers?
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2011, 10:22
  3. Part number for TDI 170 engine cover clips please!
    By jrsteeve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th September 2011, 19:46
  4. Help - Part Number for Motor Intake Manifold Flap - EGR Valve
    By miszka20 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd July 2011, 20:02
  5. Inlet gasket part number.....
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2011, 20:38
