EM TuningVolks Autos
Results 1 to 21 of 21
    Oct 2013
    30
    No cruise control leads to no power steering
    Ok so only had my audi for 3 weeks. When I got the car the cruise control wasn't working so it was booked in with the dealer (not audi) to have sorted on Monday. They had it half the day and got it down to being the stalk has gone faulty. Gone back in today to have the the stalk replaced only to be left with a car with no cruise control and no power steering.
    So been told when they put the stalk in to pair up with the car, the stalk wouldn't pair up which then lead to the power steering to stop working.
    So they kept the car in and working on it tomorrow.
    Any ideas?
    Lewis583's Avatar
    Mar 2010
    872
    Sounds like they have either altered the coding within the Steering Control unit or they've not carried out the basic settings which tells the Steering ECU the steering lock stops reading.
    It is very easy to miss something on the coding and for it to disable the PAS, though I wouldn't have thought a simple column switch replacement would require the coding adjusted.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    are they vag garage ?
    Oct 2013
    30
    They took it to a local garage which apparently has some vagcom like equipment.
    bez101's Avatar
    Jul 2008
    8,510
    sorry i ment does he know what hes doin with our cars
    as above sounds like a codeing fault of he aint redone the steering angle sensor
    Oct 2013
    30
    They've had the car all day and apparently taken to another specialist.
    Whatever they have done they have really must of screwed it up.
    So I am still stuck in Leeds at my in-laws (I live in hull)
    I have to cancel some appointments I had this week, but the worse thing is my daughter is going to miss the Halloween party.
    bez101's Avatar
    Jul 2008
    8,510
    and you didnt demand a hire car ?
    Oct 2013
    30
    Just off the phone with the dealer. Car only half done. Something with the angle sensor. So another day with them having the car. Told my daughter she can't go to the Halloween party so now have to deal with a upset screaming 5 year old.
    Oct 2013
    30
    Don't have courtesy cars with it being a small car dealership.
    jphc's Avatar
    P R N D S
    Aug 2013
    Kent
    106
    I think the lesson here is ALWAYS take your car to a reputable dealer.
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,217
    Has the battery been disconnected? That usually causes a power steering warning till u drive like 100m or so
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    jphc's Avatar
    P R N D S
    Aug 2013
    Kent
    106
    Quote Originally Posted by sliced View Post
    I thought that was ESP?
    Oct 2013
    30
    I have no idea. I'm only relaying what I have been told. It's still with the dealer. I've not been in the car since Monday.
    sliced's Avatar
    Jun 2012
    1,217
    Quote Originally Posted by jphc View Post
    ESP and power steering light
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    If they were just changing the stalk then they don't need to touch the coding as they aren't retrofitting it, it's a 15 minute physical swap only. They've obviously managed to break something (probably steering angle related) and don't know how to fix it.
    You have to remove the steering module from under the wheel with the angle sensor to change the stalk so it's definetly something they've done.
    jphc's Avatar
    P R N D S
    Aug 2013
    Kent
    106
    I stand corrected, sir.
    Oct 2013
    30
    Just got the car back after 4 days.
    Work done consists of;
    Reset coding sand basis settings of traction sensors, steering sensors and column module.
    Reactivate cruise control.
    Just realised when pulling up at home the rear wiper arm is not working
    ...."insert many curse words here"....
    Oct 2013
    30
    okay just plugged brother-in-laws dumb vagcom in and new errors have come up.
    Address 17: Instruments
    Controller:
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 25: Immobilizer
    Controller:
    No Faults Found
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Quote Originally Posted by Audiohitch View Post
    they have a probably deactivated the rear wiper by mistake, just code again under steering module 16.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    May 2012
    RETFORD, NOTTS
    1,753
    Im in hull in the morning, i can make it early if you need to, and scan with a proper vcds. Any good to you? if id seen this thread sooner i would have offered to help.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,406
    Wow that's a 1 hour job to replace cruise stalk and code the power steering, 4 days is a joke!
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
  1. Cruise Control Steering Module???
    By Avus Sportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st December 2010, 17:51
  2. More Power with Cruise Control
    By S3KO4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2010, 18:16
  3. MF Steering Wheel and Cruise Control
    By C14GSY in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st March 2010, 00:18
  4. Replies: 8
    Last Post: 11th March 2010, 13:03
  5. HELP!!?? Cruise control retrofit steering wheel module part number???
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th June 2009, 11:18
