Sky InsuranceAH Fabrications
Thread: Turbo problem
    Sep 2013
    20
    Turbo problem
    I bought my 2007 A3 2.0tdi 140 around 6 weeks ago. On several occasions now when you open it up on a dual carridgeway the car looses all power and goes into limp mode. After turning the engine off and waiting a few minutes everything works fine again.
    I have been told and also read up on here that this is or could be due to a problem with the VNT vains sticking inside the turbo.
    It seems most people just put a replacement turbo on and everything is fine again.
    Is a recon turbo the way to go? If so whats the best place to get one? Is it on an exchange basis when buying a recon turbo or just buy it out right?
    And is it worthwhile possibly looking at uprated/hybrid turbo's if I plan on getting a remap once its all running right.
    Last question could it be anything else causing this problem as I don't want to spend money on a turbo to find its something cheap and simple to replace.
    Ant
    27,097
    You would need a scan to check what the causes are, but I suspect its overboost & thus sticking vanes, which means removal & clean if not damaged internally or replace, we've done quite a few of these on BKD's already, what's your general location?
    Sep 2013
    20
    I have had it scanned, was told it was overboost. Whats the turn around time on removal and clean? Plan was to get a recon turbo then just swap it over so the car isn't out of action for more than a day.
    I live in Bristol
    27,097
    Same day usually, as long as its not got any connecting parts with issues, if the turbo's got problems internally because of the vanes clogged, then of course it would be best to fit new of which we can source aswell.
    Sep 2013
    20
    Do you carry replacement turbos just incase? Pm me some prices of what you can offer.
    Ant
    27,097
    No, turbo's are ordered per job & for example we recently removed one & found the exhaust wheel had parts broken of & missing, probably went into cat or through, we were swapping out for new anyway for that particular customer.
  1. Turbo problem's or Mass Air Meter?
    By MrFluffyBunny in forum Diesel forum
    Last Post: 7th March 2006, 23:59
  2. A4 1.8T Turbo Problems
    By polycage in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th August 2005, 23:01
  3. Loss of power. Turbo problems?
    Last Post: 28th May 2005, 08:03
  4. my turbo problem
    By avvy in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th June 2004, 16:41
  5. Power Loss / Turbo Problems??
    By pafitoui in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2004, 11:38
