AH FabricationsChris Nott
Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By Artimus
Thread: Strange tyre wear - any idea?
    Dec 2007
    35
    got this strange wear on my OSF tyre. I've had the wheels aligned about 6 months ago but that hasn't really helped. I imagine pot holes or crap roads have maybe knocked the slignment out but wondering if it is someting else.
    I now need to get new fricken tyres as the fronts are badly worn.
    2006 Black A3 Sportback 2.0TFsi Quattro S-Line
    Apr 2013
    bham
    55
    9 times out of 10 its due to your tracking or unless the wheel is warped and is that the only side its wearing on like that?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,826
    Wear on both outer edges is usually a sign the tyre is under inflated... Put some Air in it.
    MartayMcFly and batch like this.
    2009 A3 SB 2.0T DSG S line
    Dec 2007
    35
    The drivers side is worn too - out and in but the OSF is particularly bad on the inside. It's like a flat ridge has appeared that's slowing balding the inner wall.
    Dec 2007
    35
    Sure the pressure is good. Will check later.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,826
    A3's need high pressures. The amount varies from spec to spec, So check your sticker either inside the filler flap or on the drivers door end
    Feb 2009
    Aberdeen
    2,603
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Definitely looks like under-inflation. The tyres also look a bit stretched... might just be the angle?
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    May 2012
    RETFORD, NOTTS
    1,748
    under inflation. If theres a lot more on one side of the tyre than the other could also be a tracking issue.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Sep 2012
    Dartford
    33
    I'm with most of the others on this, normally if the tyre is wearing down on each side its under inflated. Hopefully thats the case as its a nice easy fix
    Sep 2013
    Portsmouth
    238
  1. Strange tyre wear
    By alpesh26 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th February 2013, 12:29
  2. Odd rear tyre wear! Any ideas?
    By AndymacA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th March 2009, 20:03
  3. Another broken rear spring.....and strange tyre wear.
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2009, 11:43
  4. Strange Noise !!!!!!!! Any Ideas
    By markcass in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th September 2007, 23:54
  5. Strange electrical prob - any ideas?
    By CamV6 in forum TT/TT-S/TT-RS Forum
    Last Post: 8th March 2007, 22:23
