Chris NottJMB Retrofits
    May 2013
    9
    Audi A3 2009 1.6l Petrol Sport - Coolant leak, help?!
    Hello all,
    I have only had my car for a few months, it only has 47800 miles on and I seem to have a coolant leak. On saturday when driving the warning light came on and asked me to pull over to check coolant level. When I stopped it was below the minimum line so I topped it up to the max line. Now Monday morning I got to drive my car and the coolant is somewhat below the minimum line again.
    Any ideas? Cost etc?
    Chris
    27,099
    Needs a pressure test done mate, maybe a leaky rad corner, split pipe etc, when its not wet outside, try leaving some cardboard underneath overnight with bricks on so doesn't blow away to see if its leaking & a rough area where to look for the liquid run, then with a torch you should be able to see the staining, unless its internal, but no issues starting I assume?
    May 2013
    9
    Cheers mate, no issues starting. Will try the test you mentioned hopefully tonight. Just hoping it's not too expensive.
    Chris
  1. Coolant Leak... Help with part name/number
    By Maz in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2012, 13:17
