    Sep 2013
    Glasgow
    7
    2009 2.0 cr140 tdi cutting out
    Hey guys does anyone know what would cause these to cut out only when cornering , also had a slight whistle from engine between 70-50 mph on overrun, always stopped at 50. Also driver door won't open when you press the fob!? Just looking for ideas as the car is away back to garage under warranty, forgot to mention she has only done 39k
    Oct 2013
    If it wasn't for the fact you said while cornering, i would say you have a split turbo/intercooler hose. That would cause the whistling..(air leaking under boost) and the cutting out. Do you have check engine light?
    Sep 2013
    Glasgow
    7
    Yes I would of thought with the whistling it would be a boost leak, but for it to cut out only on corners is weird otherwise I would of said boost leak as u have said, let's see what audi have to say about it when I phone on Wednesday
  1. 1.9 tdi cuts out int as soon as start from cold?
    By glenandem in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th February 2013, 22:50
  2. GOLF/A3 2.0 TDI BKD Warm Cutting out/Starting Problem
    By Oak Dub in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2011, 19:33
  3. HELP PLEASE A4 TDI CUTS OUT
    By nazS3 in forum Diesel forum
    Last Post: 25th November 2010, 13:07
  4. 2.0 TDI cut out after 30 seconds of running
    By heeman10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th September 2010, 20:37
  5. Replies: 11
    Last Post: 15th November 2009, 20:01
