EM TuningMonster Motorsport
    heliflyer's Avatar
    Jan 2009
    Chesterfield
    151
    elec window diagrama3
    Hi as per the title i have searched the forum and cannot find diagrams of 8p model a3 sline just wondered if anyone has a pic off inside the door of a a3 sline 05 elsawin type diagrams my drivers side elec window has stopped working ,removed the door card tested motor works fine what i did see inside the door was a broken cable but as the weather was windy and raining didnt go any further thought id have a look at diagram to see where the cable should be attached and how easy is it to get to many thanks in advance Ian
    A3 2.0T S Line Quattro
    Mar 2012
    369
    I've done this job. Quickest way is to get the whole regulator and cable assembly from somewhere like GSF - about 75 quid, then folllow the Haines manual process. Ther's an 8L guide online, but 8p is differernt.
    Edit - did you mean broken electric cable?
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,292
    Your cable will be snapped on the regulator, your best just changing the full thing... you get new cables kits on ebay but are near impossible to fit....
    new 1's from euro car parts for £80 each or something....
    Easy enough job, just a bit fiddly
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    heliflyer's Avatar
    Jan 2009
    Chesterfield
    151
    Quote Originally Posted by JohnE View Post
    Hi thanks for the reply it was a steel cable just hanging in the doorlooked as though it had snapped from somewere as it was throwing it down i just put it back together cheers Ian
    Mar 2012
    369
    +1 from me or buying the whole thing from GSF or similar - I tried fitting just the cables bought from eBay - bad idea, ended up buying the whole regulator assembly from GSF. You have to take the whole top frame out - looks a bit scary but not that hard to do if you work methodically. I had to adjust my door frame after refitting (again not hard) as I'd put it back without adjusting and had a lot of wind noise around the door seal.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,292
    yep 2nd that.... I dont quite understand his reply to be honest about how he fixed it?
    Biggest issue on re-fitting, is re-alignment for leaks and also sometimes if its out of alignment slightly then the window will go right up and then come back down to half way because it thinks its jammed....
    1 tip on changing a new regulator though, wd40 each pulley and cable on the new unit before intstalling as they are very stiff as standard
  1. polo elec windows
    By Bayleaf in forum Volkswagen and other VAG
    Last Post: 5th July 2007, 21:46
  2. One touch elec window
    By arthurfuxake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th September 2006, 10:21
  3. creaking steering and elec windows prob
    By wmd10 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th June 2005, 13:21
  4. new user help with elec window control
    By imported_kenloen in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2005, 08:12
  5. dam elec windows
    By pwnorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th September 2003, 08:37
