EM TuningBadger5
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By yorksphil
Thread: S3 erratic idle
    Aug 2013
    11
    S3 erratic idle
    Hi guys
    I have a small issue with my S3. Occasionally the revs will not settle. It is usually when the engine is up to temperature. It will either be very lumpy under 1k revs. Or will rev it self to 1.5-2k. And then settle back down and repeat.
    Does anyone have any ideas of the first place to look and what the possible causes could be?
    Matt
    Aug 2013
    11
    You can hear the car revving itself here. When I get in to the car the first rev is me to make it settle after that she does it all by herself!!
    Aug 2013
    11
    Wrong link above. Not sure how to edit.
    http://static.photobucket.com/player.../VIDEO0024.mp4
    Aug 2013
    Richmond
    20
    Hi, my 2.0 tfsi was doing this the other week, turned out that the pressure control valve was faulty....
    Put a new one on and problem was sorted.
    i'm sure others will advise, if I'm wrong!
    matthewson likes this.
    Aug 2013
    11
    Quote Originally Posted by yorksphil View Post
    Cheers buddy. Do you have a part number and price?
    Aug 2013
    Richmond
    20
    I paid just over £44 for the pair, you may get away without the gasket, mine was ok ....
    I presume S3 is the same as 2.0 tfsi....?
    valve is 06f 129 101 n
    gasket is 06f 103 483 e
    easy fix .... just take airbox off and it's looking at you...
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Can you give us an update on the outcome of this as I have the same and replaced my pcv last year so should be all good so let me know if this fixes it.
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
  1. Erratic idle
    By RobI in forum A2 forum
    Last Post: 23rd February 2012, 21:06
  2. Erratic idle
    By Ewok in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th September 2006, 11:34
  3. Friends A6 Cuttiung Out and Erratic Idle
    By myrichdad in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th September 2005, 21:15
  4. erratic idle??
    By MickA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2005, 10:39
  5. Audi 80 1993 2.0l Erratic Idle... Help???
    By imported_stephens_aj in forum Classic Audi Forum
    Last Post: 28th July 2004, 21:44
