Sky InsuranceVolks Autos
    Oct 2013
    Exclamation Rev Counter weird - A3 2.0 TDI (2004)
    Hi,
    I've tried searching all over the internet and forum for a fix to my problem but to no avail so here I am posting for help.
    Basically when the engine is switched off the rev counter sits at over 6000 then when I switch it on it may go back to 4000 and then continue the revs from there as though it's at zero.
    Another time it might work fine and then the next time it may start off in the minus position and then only go to a maximum of 3000 when it should be near 5000.
    Has anyone had this problem before and is there a simple fix? I have just bought the car and has a 3 month warranty. The car dealer mentioned using the other spare key which I did and this worked for a day and then it went funny again. I can take it back for repair but would like to know what the problem was exactly so I don't sound like a doofus.
    Any help appreciated, thanks.
    26,749
    Welcome to the site.
    If the rev counter isn't staying in correct positions even when engine turned of, then either its jumped of a cog in rear of cluster or the cluster is buggered.
    If it is indeed the cluster, then we can offer a replacement/install facility, but we're based down brighton way for this particular work, of which many have driven too for us to resolve.
  1. TDI rev counter :(
    By evilscotsman in forum Classic Audi Forum
    Last Post: 7th September 2013, 13:33
  2. just bought 2003 AUDI A4 TDI SPORT - rev counter problem
    By ATAUK in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st March 2013, 10:24
  3. 2.5 tdi v6 limp mode and rev counter problem
    By eliasuk98 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd February 2013, 17:43
  4. Tdi rev counter stuck past 2k revs?
    By k17rpo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2008, 19:47
  5. Abs warning, no aircon or rev counter
    By imported_rst99 in forum General Technical / How To
    Last Post: 2nd August 2004, 09:30
