Chris NottVolks Autos
Results 1 to 8 of 8
    Aug 2006
    NI
    785
    wheels sitting at different offset in rear arches- one wheel rubbing arch
    So I bought some new wheels (OEM A8 wheels) and fitted them yesterday. get a little scrubbing on the drivers side rear so had a look and the drivers side wheel sits further out than the passenger side. Camber looks similar on both sides.
    Is there anything mechanical that can be off to cause this? And subsequently allow it to be fixed.
    My only other thought is that the car is bent but would rather not go there.
    Talking about 10mm of difference Id say. Surprised its rubbing as its only 8" ET47 vs 7.5" ET54 so around 13mm less offset than the std wheels.
    Cheers all.
    back to boost, oh how I missed thee....
    Jason-3.2's Avatar
    May 2012
    Bracknell
    177
    You sure all the wheels are the same offset?
    Aug 2006
    NI
    785
    yup they are the same. Actually ET48.
    Feb 2012
    Northumberland
    88
    Quote Originally Posted by pablo View Post
    i have them alloys A8 sport on my S3. they shouldn't rub at the back mate. check your alignment.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,843
    swap them side to side to see it the rub moves with the wheels.
    2009 A3 SB 2.0T DSG S line
    Aug 2006
    NI
    785
    Quote Originally Posted by azialex View Post
    is there anything alignment wise that would affect that? Toe and camber *look* about the same both sides.
    Quote Originally Posted by Artimus View Post
    defo not the wheels I measured from the brake disc to the spoke of the wheel and identical both sides. There is some loose trim on the rubbing side I think thats causing the rubbing but the wheel does defo sit out a bit further than the other one. no doubt about it.
    might swap them anyway just for my own sanity. Im holding off an alignment until I decide what Im going to do suspension wise.
    Feb 2012
    Northumberland
    88
    i had rubbing problems with 18 x 8 43 offset alloys, then i went to get an alignment done and can't remember but camber or toe was negative one side. they adjusted it and there was no rubbing but with offset 48 (A8 alloys) i never had any problems with.
    Aug 2006
    NI
    785
    think Ill try an alignment then and see. cheers
  1. Different offset wheels on an S3?
    By Ivo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2010, 12:23
  2. different offset and tracking
    By jase0851 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th August 2007, 04:39
  3. Fitting alloys with different offsets?
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th November 2005, 14:22
  4. Wheel/tyre size differences from std fit- inaccurate speedo??
    By trekbiker in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th October 2005, 19:28
  5. want to finish the wheels in a different colour..
    By richy in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 14:59
