Badger5JMB Retrofits
Results 1 to 7 of 7
    Oct 2013
    Hello all! Need help.
    Hello Everyone, i am new to Audi Sport.
    I came here looking for some advice after searching the internet for hours i cant find anyone who has had the same problem.
    If i have posed this in the wrong section, admin please just remove!
    Well... Not long ago my Audi A3 8p 1.6FSI started to have a rough idle.
    it would idle between 500RMP and 700RPM, bouncing up and down!
    Then it started to get worse,
    when driving, if i drop the clutch the Rev's drop to almost 100rpm, like the car is going to cut out.
    It also struggles starting without any help from the accelerator.
    Then my engine management light appeared. With the fault code P2208 #10 - NOx Sensor Heater Sense Circuit bank 1.
    So... i changed the lambda sensor after posts online forwarded me to this.
    One day later after clearing the code and replacing the sensor, all the same problems are still present! and the fault code re-appears!
    Please if anyone could give me some advice on what this problem could be that would be great.
    Thanks Jack
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Have you checked for vacuum leaks?
    Oct 2013
    Hi MrLapou thank you for your response,
    No i have not, how would i go about doing that? i have checked around the throttle body and seems all ok.
    thanks
    Oct 2013
    Aberdeen
    21
    lambada censor?
    Oct 2013
    Hi S3eddiet, I had changed the sensor to a brand new one. any chance it could be faulty from the factory?
    Oct 2013
    Aberdeen
    21
    could be but dont think it would be that, as MrLapou suggested i would check all the hoses for leaks.
    Oct 2013
    How would i check for vacuum leaks? is this with all the coolant pipes? and maybe the engine breather pipes blah blah?
    thanks
  1. Hello all :) some advice needed
    By James101 in forum The Welcome Section
    Last Post: 29th October 2008, 11:06
  2. Hello Audi owners: HELP NEEDED
    By volps in forum The Welcome Section
    Last Post: 15th September 2008, 12:27
  3. Hello everyone and Help! 2.6 Coupe advice needed!
    By AudiCoupeTim in forum Classic Audi Forum
    Last Post: 25th March 2007, 18:13
  4. Hello all newbie with help needed.
    By jraw4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2007, 20:07
  5. HELLO ALL - URGENT HELP REQUIRED - READ MY POST BE
    By leespears1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2004, 19:38
Tags for this Thread
