Badger5Chris Nott
Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By S3Alex
Thread: stage 2 + miltek
    Oct 2013
    Aberdeen
    21
    Question stage 2 + miltek
    anyone any eider as to how much BHP i would be putting out with the above done to my s3.
    turbo back miltek and no other mods apart from stage 2 remap which is needed with this exhaust as far as i have been led to believe.
    thanks in advance,
    ed
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    Quote Originally Posted by S3eddiet View Post
    thanks in advance,
    ed
    Hi Ed,
    Stg2+ is the HPFP upgrade,plus Stg2 mods,and will give you an average of 360-370bhp,and around 360-380lbs torque.
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,470
    stage2 is nothing much to like really... as you sacrifice a lot of low end and mid range torque due to weak fuel pump, only above 5k i noticed improvement, not to mention fueling problems and else, go straight stage2+ and you wont be disappointed, How stupid was I thinking that stage2 is something in between stage1 & 2+. Its just stage1.5 with extra noise.
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    Oct 2013
    Aberdeen
    21
    im not sure what has all been dont, i just know it is a miltek turbo back, i am not even sure if it has been remapped and if there is a way i can check and tell if it has been done.
    what would i need to do if i was to go for the stage 2+ map and what benefits would i notice?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    You'll get not only more power,but a LOT of extra midrange torque,right where the car needs it.
    Any tuner should be able to tell you if it's been previously mapped,and to be honest,there would be no point in fitting a full exhaust otherwise.
    Oct 2013
    Aberdeen
    21
    Quote Originally Posted by S3Alex View Post
    thanks for the info Alex, i have only had her for 3 weeks and the miltek was already fitted, if it is just the miltek that is fitted would i be better getting anything ells done before i go for a stage 2+ map? is the stage 2+ map a base map or will it be set up for the way my car runs and the mods that are on here?
    sorry for all the questions
    Dec 2008
    278
    2+ requires a cold air intake and upgraded high pressure fuel pump. Probably looking at £600ish for the pair - depends if you spot some second hand bargains!
    The Stage 2+ map is designed to work with those mods, and has a degree of flexibility in terms of being set up to work with your car, within a defined set of parameters.
    Oct 2013
    Aberdeen
    21
    will it make it better on fuel or will it drink a bit more?
    old subaru sti ppp+ driver with 380 bhp so i am used to drinking the fuel but would be nice to drink a little less
    Jun 2012
    Chester
    570
    Visit Dave-S3's Instagram Channel
    Quote Originally Posted by essIII View Post
    Stage 2+ revo or (Stage 3 shark) on a manual car requires the following:
    Full turbo back exhaust, this includes the downpipe & sports cat. Approx £1200 (Miltek)
    High pressure fuel pump and cam follower. Approx £600 (Loba)
    Cold air intake system (CAI) Approx £250-400 - many makes to choose from however the one AMD designed (do a search) has been proven to give good gains on a standard system let alone a mapped one!
    The Remap either REVO or shark, shark is cheaper at £400, revo is £600 or £150 to upgrade if you already have the software.
    AND If your cars manual and running a standard clutch you will need to uprate the clutch for anything above stage 1 power. DSG as far as im lead to belive is fine
    Thats the minimum really for stage 2+, anything extra like Uprated intercoolers is a bonus but in this country its hardly necessary unless your running seriously big power on an uprated turbo & internals.
    Hope that helps!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    No worries.
    You need someone to take a look at the car and see what software(if any)is already on it,and also to find out if the HPFP has been upgraded.
    As has already been said,for Stg2+,you need the exhaust,CAI and HPFP,and you will definitely need to budget on a new clutch(assuming that it hasn't been changed by the previous owner).
    A Stg2+ map can simply be loaded,and left with generic settings,but is far better to be set up on a dyno,and then logged on the road also.
    Any decent tuner would check the car over first,then put it on the RR,and find out what it's doing,before going any further.
    If you use all of the extra power,it will return poorer MPG figures,but it's easy to simply use the extra torque,and get an improvement instead.
    Mine for instance,can still do 30+mpg on the drag into work,but if it's pushed it will get into the low 20s or less.
    Jan 2009
    125
    Alex, I think my Revo 2+ torque seems pretty low 335 lbft in comparison to some of the quoted figures on here. What's the stage 2 Revo torque figures?
    bit off topic, sorry.
    S3 Revo Stage 2+
    Milltek Non Res-ITG-Autotech HPFP-Loba SMF
    Jun 2012
    Chester
    570
    Quote Originally Posted by gilberto View Post
    Figures from Revo website:
    Power (bhp)
    Power (kW)
    Torque (lbft)
    Torque (Nm)
    Stock OE
    260
    194
    258
    350
    Stage 1
    305
    227
    312
    423
    Stage 2
    335
    250
    310
    420
    Stage 2+
    367
    274
    353
    479
    # Dyno tolerance +/- 5%NOTE: Revo Power is dependant on fuel quality and Performance Settings
    Jan 2009
    125
    Cheers, about 20 lbft short but could be down to the dyno/conditions on the day I presume.
    S3 Revo Stage 2+
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    As you say.....don't be overly worried by it,as all sorts of factors make an impact on power and torque,and 20lbs amounts to a few percent on the day.
    My car struggled to make even the stock power on it's first trip to a dyno,before being mapped,and each time after made just about what it was expected to,but things like air temp,fuel,heat soak,tyres,etc etc all play their part.
    Jun 2012
    Chester
    570
    Just as a side note what do people think to the auto tech HPFP? It's much cheaper than the Loba!!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    Quote Originally Posted by Dave-S3 View Post
    The Autotech's only drawback is that it's a kit,which uses parts of the existing pump(i.e. the housing),and it absolutely MUST be put together carefully,in a clean environment.
    If that's done,it's reliable,and capable of flowing sufficient fuel for over 500bhp.....I have one on my car.
    Right now though,if I was buying again,it would be the Loba I'd choose.
    Jan 2009
    125
    I'll be honest only went for it because I'd read reviews about it on here. I wouldn't know a good HPFP if it hit me between the eyes.
    S3 Revo Stage 2+
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    Like I said below...the Autotech has worked very nicely for me over some yrs now,but it was built up by AMDTuning,and not by my own fair hands!
    For anyone who hasn't got the expertise or facilities,I'd go for the Loba every time now.
    Jan 2009
    125
    Yeah the Autotech pumps worked well for me so far. I got a tuner to fit mine too.
    S3 Revo Stage 2+
  1. Miltek + stage 2 remap
    By S3eddiet in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2013, 11:07
  2. Shark stage 1 with miltek tbe
    By Gfermer in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2013, 13:14
  3. what is the problems with revo stage 2 but only cai +miltek catback! ?
    By yamatei in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2013, 10:46
  4. Replies: 6
  5. Installing Miltek TBE with APR Stage 1
    By NCRAW in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2011, 13:07
