Chris NottAH Fabrications
Like Tree1Likes
  • 1 Post By TDI140
Thread: Boost Pipe Help
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    872
    Boost Pipe Help
    I’ve had boost leak for quite a while now and oil has gotten everywhere, the L shaped boost pipe connected to the intercooler was badly worn on both side, replaced it with a new one and some new metal clips.
    The intercooler side is now a tight fit but the connection to the middle pipe is still very loose. Is there a trick I’m missing or does it also need to be replaced. If so how hard is it, because I can’t see the end of the pipe. Does it look worn?
    May 2012
    32
    The clips broke on the same hose on my car recently so it kept popping off. I had mine fixed at a garage and they told me that it's best to replace the hose and the middle plastic pipe as they generally don't fit as well if one of the parts is worn. I wasn't sure whether it was just a ploy to get me to buy another part at the time but being as it wasn't much more for the other part I went for it. Sounds like there could be some truth in it from what you're seeing.
    As for how difficult it is I'm afraid I can't help since I lazily got someone to do it for me. Hope you get it sorted.
    Mr. B's Avatar
    Jan 2012
    Bristol
    872
    Oh really, how much did it come mate?
    TDI140's Avatar
    May 2011
    1,293
    Its crap mate and its expensive mate, i used a new horse shoe clip and then cable tied it so it grips tighter on the hose also i have forge hoses so the coupler is much more chunky and tighter fitting than the OEM rubbish hoses
    Mr. B likes this.
    A3 2.0TDI FWD sportback with GT1756 225bhp 351ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch
    Mr. B's Avatar
    Jan 2012
    Bristol
    872
    Horse shoe clip? What is that? Have you got a link mate? Any ideas on how to remove the middle pipe? I'm half tempted to tiger seal the connection
    Mr. B's Avatar
    Jan 2012
    Bristol
    872
    Lol Super ghetto but If I wrap lots of tight elastic bands around the metal bit and add a generous amount of tiger seal and shove it in, do you think it will stay put
  1. boost pipe help on 1.9 afn
    By dannyvalley in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th July 2012, 17:58
  2. Help with some boost pipes please.
    By Vex182 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2012, 20:43
  3. Boost Leak - Pipe Help
    By Nilz in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2010, 10:35
  4. 1998 AGU Turbo Intake Pipe; Help?
    By Tallpaul in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2006, 10:39
  5. Replies: 11
    Last Post: 15th August 2005, 20:01
