Chris NottEM Tuning
Results 1 to 32 of 32
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    730
    The remote doesn't work
    The batteries in both my car's keys have gone. Unfortunately I haven't changed them as soon as I've noticed they are about to go and now, even with new batteries, the remotes on both of them are not working.
    The LED on the keys are lighting red.
    I've tried all the procedures to recode them I found without result.
    I've tried
    - this one: how to program a vw, seat, audi coded key, when new battery fitted, or recoding new key. - YouTube
    - this one: How to programme your audi key fob ( Instructions )
    - this one: How To Program Reprogram Your Audi Remote Key Fob - A4 | eBay
    - and both these ones: Ross-Tech: VAG-COM: Remote Control Matching Info
    The Ross Tech mentions at some point that in Central Convenience - Measuring Blocks - group 003 or 007 I should find a field that will show how many remotes are stored. There is nothing like this in any group.
    How do I match the remotes again?
    Does the red LED flashing on the keys when I press a button means something? Does it also light in green in some cases?
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    26,776
    With vcds, delete all stored remotes 1st, then add new ones.
    6+1 Gears
    Jun 2009
    Romania
    730
    How do I do this? I've tried to delete them all using the procedure from Ross Tech. Still no result.
    26,776
    I just went into appropriate channels & removed all keys, then added both, 1 after another by depressing fobs buttons, which is signified by the indicators flashing.
    6+1 Gears
    Jun 2009
    Romania
    730
    At one point, when I try to code them, after pressing any button on the key, the indicators are flashing twice. This is the only result I get. This tells me that the car "sees" the remote but doesn't save it.
    Kaibo's Avatar
    Jun 2011
    Middlesex
    354
    I'm sure you can lock unlock with the key and then press the fob buttons to resync them
    6+1 Gears
    Jun 2009
    Romania
    730
    Did that too! No result.
    26,776
    If it flashed, then it sees the keys, I would contact RT & ask for some further advice if its not working properly, making sure the keys were deleted before adding again.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    934
    What is the battery type on 2004 remote fob?
    VCDS USER
    6+1 Gears
    Jun 2009
    Romania
    730
    2025
    6+1 Gears
    Jun 2009
    Romania
    730
    Unfortunately I don't think this is an option for me as I don't have a genuine cable. Too expensive for me since I don't use it too much and I don't make any money with it.
    If there was a cheaper option, like something that links to my car and can't be used on another one (like the Bluefin), I would buy. I'm not a fan of replicas, clones, imitations etc. and this can be seen in my car. Almost all the mods are retrofits to better OEM or better equipment.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    934
    Quote Originally Posted by Johnny Bravo View Post
    2025
    Thanks!
    VCDS USER
    26,776
    With respect, you've spent an absolute fortune on your car, so don't tell me its expensive to buy a genuine interface, sorry but I disagree & thus as its fake, I'm sorry but I cant help you any further.
    craigynett's Avatar
    Apr 2006
    in a nice small & quiet village on outskirts of huddersfield!!
    282
    Add craigynett on Google+
    i went a 2006 A3 while ago where both remotes had stopped working with the remote locking. Erased all the keys with VCDS then programmed them both again. The indicators flashed with each remote but for some reason neither of them worked after programming. Tried it several times, indicators flashed each time but remotes wouldn't operate the remote locking.
    In the end i got a remote out of my van with the correct part number & tried that. Went through programming process & the remote worked perfectly. Got a 2nd remote from the van &n that also worked! Was very bizarre. I also did a 2007 Octavia key on Saturday. His original remote had stopped working. I tested it & it was sending correct mhz signal but wouldn't program to the car. Tried new remote, worked straight away
    Please contact Admin if you wish to advertise your business/services on the forum
    6+1 Gears
    Jun 2009
    Romania
    730
    Why woud this happen? Just because the battery was not replaced in the propper time, the remote can't be programmed again?
    craigynett's Avatar
    Apr 2006
    282
    as long as the remote isn't faulty it can be programmed repeatedly even if it takes you 6 months to change the battery! I've done keys for 3-4 cars now where the remote has stopped working with the car even though it's still sending an RF signal but even after clearing all the remotes from the car the original remote still wouldn't program back to the car with VCDS. The 1st time it happened was with the A3 i mentioned above & was a forum members. I spent ages trying to program his original remotes with no joy. So i tried a remote from my stock & it worked straight away. I showed the lad every step of trying to program his remotes & my remote to show him they weren't working
    I have no idea why it happens, i just know that it sometimes does & they only way i've been able to sort it is to do a new remote
    May 2012
    RETFORD, NOTTS
    1,716
    I finally got to te bottom of a similar issue last night. When adapting each remote, this particular remote had to have the unlock or lock button pushed for 5-6 seconds before vcds 'recognised it' functions as it should now.
    Also an S4 that needed to be locked and unlocked after each remote was programmed individually! All cars are different. This is why its worth buying genuine tools, its one less thing to worry about going wrong.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    craigynett's Avatar
    Apr 2006
    282
    tried that & pretty much everything else i could think of. Spent about an hour with it before i tried 1 of my remotes. Had it with an Octavia last week as well
    6+1 Gears
    Jun 2009
    Romania
    730
    I'll see someone who has a original VCDS cable next week and try again.
    If still won't work, what can I do? Can I buy only the remote? Is it different than the immo chip that allows the engine to start?
    craigynett's Avatar
    Apr 2006
    282
    if it doesn't work you can buy a 2nd remote from Ebay then just fit the remote circuit board into your remote case. The immob chip will still be inside your original case as it's not fitted to the circuit board. Then just program the remote.
    Just make sure you buy the correct part number for your car as there's a few different Audi remotes that look identical but aren't compatible
    8p0837220d is correct remote for 2006 A3
    GENUINE AUDI ,A3,A4,A6,A8,Q7 ETC..3 BUTTON REMOTE ALARM KEY FOB UNCUT BLADE | eBay
    6+1 Gears
    Jun 2009
    Romania
    730
    Those look like my keys. If I won't fix this with my keys, I'll give it a try with a key from ebay.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    934
    2025
    The battery was actually 2032.
    Not sure why, after putting new one in the remote open/lock is not working.
    Key starts the car ok still.
    VCDS USER
    6+1 Gears
    Jun 2009
    Romania
    730
    Yes! Yesss !! Yeeeeeesssssss!!!!
    I've managed to recode one of the remotes.
    This is what I've done:
    - key that needs to be coded in the ignition
    - ignition ON
    - Central convenience - Coding - Long coding helper - Byte 8 - uncheck the option Manual remote control learning/unlearning active than close, Do it!
    - Central convenience - Adaptation - Measuring Blocks - channel 00 - read - save (this is supposed to remove all the remotes that are programmed at that time)
    - Central convenience - Adaptation - Measuring Blocks - channel 01 - Enter 2 in the New Value field than Test and the next field, Stored value should show 2 - than Save.
    - press and hold one of the buttons (I've pressed Lock) and hold it until you count to 10 (you should see the signal lights flashing once or twice)
    - THAN (AND THIS IS WHAT MADE THE DIFFERENCE AS I DID THE PROCEDURE THREE TIMES TO MAKE SURE AND ONCE DID NOT WORKED BECAUSE i DID NOT DO THIS STEP) remove the key from ignition and press a button ON THE SECOND REMOTE. You should see again a confirmation blink
    Now try the remote on the key that was in the ignition, it should work now. In my case, the second remote still doesn't work but it is a must to have it with you.
    I've tried the procedure without pushing the button on the second key and it did not worked.
    Give it a try an see if my procedure works with your remotes.
    craigynett's Avatar
    Apr 2006
    282
    had a mk4 Golf with the same problem this morning. His remote had stopped working. I tested it & it was still sending a signal but wouldn't reprogram back to the car. Tried a new 1 from my stock & it worked straight away
    craigynett's Avatar
    Apr 2006
    282
    when you type in "2" as stored value that's doesn't program 2 remotes. That just programs whichever remote you then press a button on into remote position 2. There's 4 positions in total & each remote needs it's own position.
    So go back in with VCDS & type in "1" then once you've clicked save you press & hold a button on your unprogrammed remote
    craigynett's Avatar
    Apr 2006
    282
    Quote Originally Posted by SAiLO View Post
    it will still start the car ok because the battery has nothing at all to do with the transponder(immob chip) in the key. It's totally separate. In your sig it says you're a VCDS user so just reprogram your remote
  28. #27
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    934
    Quote Originally Posted by craigynett View Post
    Didn't have a chance to do it yet but will try as soon as I can.
    VCDS USER
  29. #28
    6+1 Gears
    Jun 2009
    Romania
    730
    Yes but as long as the stored value was 1, I couldn't save any remote. Only when I've set it on 2 I was able to program one of them.
  30. #29
    26,776
    That could be because it still sees remotes coded to the car, so you need to delete all remotes 1st, then star afresh, as for removing key from ignition, then pressing button on 2nd, never had to do this, always with 1 key in ignition & pressed button on both, not at same time & indicators flashed.
  31. #30
    craigynett's Avatar
    Apr 2006
    282
    if you erase all the remotes & start again then try position "3" for the 2nd remote if it won't adapt into position "1" & see what that does
  32. #31
    26,776
    You can erase all remotes, then go into relevant areas & see if the erase took effect by showing zero remotes enabled, if it still shows remotes then of course no point trying position 3, the ideal situation is to remove all & start again or if there are other remotes in the wild, they could be used to open the car, which has been known to happen unscrupulously & cars go missing of drives.
  33. #32
    6+1 Gears
    Jun 2009
    Romania
    730
    As you can see, before coding what I did was to remove all the remotes that were stored.
    I'll try again these days to code the second remote.
  1. Turbo doesn't work straight the way ? Help please
    By lewis.bates.73 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st October 2013, 11:51
  2. 1999 audi s3 remote locking doesn't work
    By leess3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2011, 05:42
  3. Remote key not working
    By gradwells in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2010, 22:48
  4. Makiing the auto time correction work?
    By rickquattro in forum In-Car Entertainment
    Last Post: 19th November 2004, 15:22
  5. the instant greamlins dont work in the footy forum
    By CARACTERE007 in forum General Chat
    Last Post: 5th January 2003, 22:08
