Monster MotorsportChris Nott
Results 1 to 16 of 16
Like Tree2Likes
  • 1 Post By LEE69
  • 1 Post By G020G
Thread: Fitting H7 Dipped Beam/W5W Side light - PAIN IN THE &£$@!!!
    G020G's Avatar
    Jun 2013
    London
    13
    Hello everyone,
    I took the plunge and decided to get the OSRAM Nightbreakers Plus for my 07 A3 S-line Sportback as stock headlights are beyond awful. Got them yesterday and I searched around here for advice on how to get to the bulb housing and obviously getting them fitted however I have had NO LUCK...and I mean NO LUCK in getting these fitted.
    I called about a few garages in Nottingham to possibly have them fit it for me and I'm getting ridiculous quotes of up to £40 for fitting the bulbs?!
    Can someone kindly provide some suggestions or if anybody is in or around the Nottingham Area (near Nottingham Trent University) and wouldn't mind giving me a hand, I would greatly appreciate it.
    Cheers,
    G
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    788
    Use a mirror to see the 3 clips they are held in by, remove the wiring connector then pop the bulb out by pushing down gently and they the other 2 clips let it go.Dead easy when you have done it once.
    Sidelights are the gits lol
    sliced likes this.
    Growing old is mandatory, growing up is optional
    pwilliamson1991's Avatar
    Aug 2012
    UK
    70
    I changed every single bulb in the front of my 1.9 A3 at the weekend. However I'm thinking it might possibly be different for a bigger engine i.e 2.0. Are they low or high beams? To replace mine I had to just undo the cover into them (low beam you slide a bracket across and it pops off) (high beam you undo a clip and pull the cover back towards the windscreen) slide my hand in and unplug the existing bulb from its bracket. Then unplug it from the attached wire, the plug the new bulb in and push it back in! that simple!
    Aug 2012
    UK
    70
    Changing the side lights is by all means "doable" just takes some time fiddling about. I pulled some strange shapes changing the passengers side one. Its a long reach into the bulb!
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    788
    Use long nosed pliers to grab the bulb holder for the side lights
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    I'll do it for £20!
    VCDS USER
    c_w
    1,044
    The spring clip system on the A3 headlights is pretty easy compared to most cars these days and can be changed prety quickly. Space is tight but at least you're not trying to put the thin metal tin clips on the back.
    Jan 2012
    SW London
    751
    Whereabouts in london are u?
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    G020G's Avatar
    Jun 2013
    London
    13
    Thank you everyone for your responses. I have tried to put some of your comments into practice but the car just wont budge, also I am worried that even if I do get the bulbs in, particularly the H7 - The alignment might off in which case I would have to go through the entire process again.
    SAiLO - Haha brilliant, better than what I have been offered mate! If all else fails, I'll come back to you!
    G020G's Avatar
    Jun 2013
    London
    13
    Quote Originally Posted by Sidhu88 View Post
    Sidhu88, I'm based in South London, near Wimbledon.
    G020G's Avatar
    Jun 2013
    London
    13
    Finally managed to get them fitted, got myself an A5 (booksize) mirror and a pair of crocodile-nose pliers and managed to get the little buggers in! Passenger side took a little longer, the lack of space is quite ridiculous when you come to thinking of it but all sorted for now.
    Now that Osram's are in - the sidelights that came with it (which I thought would be of the same temperature i.e 3700K) turns out to be some like mid 2K. They are very yellowish and do not look good with the OSRAMs at all. Any suggestions? should I look at LED replacements or are there any white halogen options?
    I've looked on here and there seems to be a lot of talk about these 'superwhite halogen' 501 types on ebay - but not sure what to expect in terms of quality etc.
    Thanks for your advice guys, cheers
    G
    SAiLO likes this.
    Oct 2013
    London
    121
    Quote Originally Posted by G020G View Post
    G
    Could you take a photo - I'm interested in seeing what they look like.
    Thanks!
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Speak to tr8ps about sidelight LEDs - he's a member on here.
    VCDS USER
    Jan 2011
    Bristol, United Kingdom, United Kingdom
    332
    Tr8ps is your man for those
    Now: Audi A4 B8 2.0 TDi SE - Silver, Bluetooth, Parking Sensors, Auto Lights/Wipers, Auto Dimming Mirror, Hill Hold Assist.
    Before: Audi A3 8P2, 1.9TDi Special Edition, Silver,
    Armrest, MY09 Rear Lights, R32 MK5 Alloy Wheels 18" Gloss Black, Gloss Black Sline Grill, Windows Tinted, Carbon Wrapped Trim, Wind Deflectors, Alarm Beep, LED Interior and Number Plate Lights, Cupra R Splitter, S-Line Springs, footwell lights, S3 Pedals.
    Jul 2013
    36
    I changed the sister in laws drl bulbs and I was advised from members on here to remove the wheels and arch liners which made it so much easier especially with my big hands I fitted a set of led drl bulbs from t8ups they look great
    Phil-1's Avatar
    Sep 2013
    Harrogate
    884
    Quote Originally Posted by G19rnt View Post
    I can also vouch for T8ups DLR L.E.D's. I went in through the back of the head light, lost lots of skin ;-)
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagus.co.uk
    E-Mail:info@philseagust.co.uk
  1. Replacing the small 5W bulb (side light/DRL) on the left side
    By dzankizakon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th June 2013, 22:13
  2. LED side lights and canbus wiring - side lights on all the time
    By M7R in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th June 2010, 10:41
  3. H7 dipped beam/side light leds
    By scottie123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2009, 09:55
  4. DONT ever fit LED side lights!!!!!!!!
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th July 2008, 10:15
  5. New side lights fitted
    By Buster in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2007, 10:08
Tags for this Thread
