EM TuningSky Insurance
    May 2013
    26
    Door top removal
    Evening guys,
    I'm currently swapping over door mirrors and I need to get the top of the door off to do the job properly.
    ive got Elsa and can see the basic principle, is there any tips from anyone who's done this before?
    thanks
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    What kind of car do you have? Would help
    i've changed both window regulators on my old audi... I'm pretty sure you can change the mirrors without taking the full frame out
    that was a 3dr a3
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    May 2013
    26
    Haha my bad! It's an 08 SB. Need to get access to the loom in the door to pull it out properly
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    3dr... 5dr? .... Ah yeah, remember that loom very well now... Its a wee bit of jiggery, if I remember right... I pushed the loom through 1st, take all the bolts out and wiggle left/right to get frame out...
    putting it back in was a bit more of a challenge... Need to try balance it in the door 1st, put the loom down 1st and have a set of long nosed pliers handy... The hardest thing I found was the re-alignment... Juat need to check your door shuts line up correctly once the doors closed to prevent leaks... Bit of a faff but easy enough
    May 2013
    26
    Quote Originally Posted by S3_Jacko View Post
    right ok cheers! Might give it a try tomorrow if the weather holds out. Got to replace the outer window seal strip aswell as mines looking knackered. I'm hoping I might get away with just sliding that on without taking the door top off if I don't get that far
  1. A4 Avant door card removal
    By AndyMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th July 2005, 23:10
  2. S4 lower door skirts- Removal?
    By The911SC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th June 2005, 22:06
  3. Near side front interior door trim removal advice?
    By Greytop in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th January 2005, 18:49
  4. door card removal?
    By unikarl in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th December 2004, 11:32
  5. A4 B6 door panel removal - help!
    By imported_Pottsy in forum In-Car Entertainment
    Last Post: 24th October 2004, 17:29
