JMB RetrofitsChris Nott
Results 1 to 7 of 7
    Sep 2013
    London
    62
    Idle Raising from 800rpm to 1100rpm by itself ( VIDEO)
    Does this mostly everytime i drive it. If you turn the car off and start it again it goes back to normal idle or sometimes if you rev the car it drops back down. Anyone know the reason or solution for this?
    I got the heater on full in this video but it does it when nothings on. Just to clear that up.
    Feb 2013
    Grimsby
    1,084
    WOOOAH, it starts going crazy half way through.
    i think you got gremlins pulling on accelerator in there mate.
    05, A3 8P 2.0TFSI Quattro
    kanecullen89's Avatar
    Jul 2009
    356
    Is it a 170 with a DPF? Engines with a DPF rev higher on their own when regenerating
    Sep 2013
    London
    62
    Its only the first seconds of the video i'm talking about haha. Its a 140 no DPF.
    Jul 2009
    356
    Hmm. When I had my A3 140 I had to get the intake manifold flap replaced.
    It wasn't causing this issue, it just threw up an error, but I suppose it could cause these sorts of symptoms. It's a common fault
    Aug 2010
    160
    I had this on my 140bkd clean everything out all the intercooler pipes and intercooler intake manifold even the intake holes on the head also fit a catch can or block off the ccv that goes in to the air intake
    Aug 2010
    160
    also I did change injectors and that help massively with some little problem I had I think changing injectors after 80-90k should be done on these bkds
  1. A3 BKD Idle Creeps up to Around 1100rpm Sometimes
    By Rider4life in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2013, 20:16
  2. Replies: 4
    Last Post: 8th October 2011, 18:22
  3. 2.4 v6 idle hunting and hissing from petrol filler cap
    By Oily Fingers in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th April 2011, 11:06
  4. Replies: 41
    Last Post: 28th September 2010, 14:18
  5. allroad air suspension didn't raise back up from level one!
    By reggieroo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th September 2010, 11:19
